Inspection checklist before taking delivery? 01 E55
Condition of paint, body panel alignment, interior, wheels & tire wear
Check all switches & electronics
Check for rust: spring perch, door seals, trunk key hole, rocker panels
Driving: check for steering free play, acceleration, transmission shifts, etc
Under the hood: check for general condition, inspect engine oil, all fluids
I own a 97 E420 so I'm pretty familiar with W210s. I understand the E55 will have a sophisticated onboard computer w/ FSS.
Also, I'm told that the 'dashlight by the tach' on the right is not illuminated. ?
motor mount
pixels in dashboard(sometimes cov'd under warranty by nice MB advisors)
transmission mount
catalytic converter
ignition sensors
spark plug wirings(my car's prior owner spent about $1K on this)
brake pads/rotors
good luck.
motor mount
transmission mount
catalytic converter
ignition sensors
brake pads/rotors
good luck.
what is the fix if the pixels are out? do you have to replace the whole cluster, or a single bulb? does MB USA have an extended warranty on the pixels, similar to 7yr/100k coverage on S-class?
http://www.bba-reman.com/catalogue/D...ledProduct=556
You should also listen to the engine for any type of ticking sound. This is usally caused by the lifters which is pretty comon when people use cheap oil. This is not a cheap fix so pay attention closely. The ticking gets louder as you rev the engine. Happened to my '97 E420 and I had to have all of the lifters replaced; it was bad and expensive...
Good luck!
Also Have the Shop that is doing the PPI scan the car for codes
Dont forget about the Harmonic Balancer
