Car dies after hot run...
210 E 55, 220 S 600
I am hoping some one can help me on this.....after running the car bit hard, the car just dies.....after it cools off a bit, it starts and no problems. Took it to the dealer, they state that it is my new keys, but they are wrong. Anyone else had this problem on their E55? I own 2002 E55 with about 56K miles. Recently had the spark plugs and cables replaced....thanks in advance.
w210 E55
Very common with Fords with the same symptoms. The moment the crankshaft position signal is lost, the engine will stall. Sooner or later, the sensor will go out all together (Fords CPS sensor uses magnets for the sensor.....after a while, the magnet comes apart causing the failure) It usually never sets a check engine light and service advisors would "No Problem Found" the visit until the vehicle totally will not start (unfortunately, after stranding the customer on the side of the highway) The stalls are always reported after the engine is warmed up. I hope this helps.
AMDdriven has my vote.
I had a similar experience with my 55. The car would get to 85-90°C and die. A ten minute cool-down and it would fire back up. Changed the CPS (Crank Position Sensor) and all is well. I paid about $80 delivered for the part. There is only one bolt and one wire but it's a bit tucked away on the driver's side of the bellhousing. For the price/effort this would be a good place to start.
210 E 55, 220 S 600
You guys are the best
thank you so much...i will give it a try. Will let you both know once it has been replaced. Thanks again fellas.
I'm going out on a limb here, but.......your symptoms are quite common for a crankshaft position sensor failure. Most of the time it will not set a code. (Check engine light)
210 E 55, 220 S 600
You guys ROCK!
Yep, it was CPS...CPS from dealership, $125, the labor to install from independant MB mechanic, $68....smooth running one bad *** E55, priceless!
Thank you all again. Only if the damn S600 was this easy to upkeep...
monowiper
awesome you got your car back to normal
the crank shaft position sensor just wear out with time, the little gaskets around it (o-rings) deteriorate and let oil touch the sensor thus destroying it, very common problem
