First time taking my '99 E55 for service
Old Oct 16, 2002 | 01:29 PM
Wreck's Avatar
E55
My dash indicates that I have 400 miles till the next service. I have 99' E55 which I got used and never sent it to an MB service.
I know my car is still under the orignal warrentee and I only have 21K miles on it.
My question are
1. What are they going to do?
2. It's it like my BMW where the service is FREE?
THanks
Old Oct 16, 2002 | 01:32 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
they should change the oil and filter with synthic oil ,change the air filter,,the dust filters for climate control .lube chassis and body seals/hinges,ans so on ,connect with hand held tester and cleanr any errornis fault codes....
unfortunatly service on your 99 is not free,,in northern va 475.00
if you had purscased a 2000 the service would be included for 4 years or 50k miles
Old Oct 16, 2002 | 02:21 PM
Wreck's Avatar
E55
$475. Damm.. With that kind of money I can buy something cool like a new amp or cpu or maybe alot of lap dances. Oh well there not much I do about that I guess.
Old Oct 17, 2002 | 09:14 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Over here, a typical FSS A-Service is $259.95 for 4-6-8 cylinders. It sounds like an AMG service could be more involved or a rip-off.
Here's whats done:
filter change and synthetic oil
new dust filter
inspect brake pads and rotors
rotate wheels
check and correct fluid levels
reset FFS indicator
The list doesn't seem too hard for a non-mercedes mechanic to do. I go to an independent garage for a $10 oil change with my Redline oil and OE filter and for the other stuff I don't want to do myself. The resetting of the FFS indicator is done as a favor by the dealer.
Shop around and have enough left over for the champagne room.
Old Oct 17, 2002 | 09:17 AM
DSMIT's Avatar
at 21 k miles,,,,,he dosent need a schedule a service,he needs a schedule b
Old Oct 17, 2002 | 09:24 AM
ima55r2's Avatar
You're right DSMIT
Here's a FSS B-service for $409.95
includes A-service
replace wiper inserts
lubricate and inspect trottle linkage
balance wheels
inspect undercarriage for leaks
check a/c refrigerant level
inspect V-belt
Its still no bargain.
Old Oct 17, 2002 | 09:28 AM
DSMIT's Avatar
NONE of the flex services are bargains
Old Oct 17, 2002 | 12:22 PM
Wreck's Avatar
E55
I think my next car is going to be a honda or something
They sure charge alot of visually check stuff.
Old Oct 18, 2002 | 05:22 PM
djamer's Avatar
SL 500
Flexible Service System - A-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Flexible Service System - B-Service
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
Without the warranty, it is expensive like others said. But standard oil change/filter by a reputable Euro shop should be $70.00, unlike 125.00 at the dealer..
djamer
Old Oct 19, 2002 | 11:49 AM
pocholin's Avatar
Volvo V90 CC
I recently had mine serviced, I paid 385 for the service, they didn't change air filters, but replace the wiper blade (what a waste, that blade was perfect)
