Does W211 AMG spare tire fit on W210??
Hey guys, do you know if the W211 AMG spare tire will fit on W210?? SInce i got the BBK my brand new from factory spare tire, never been mounted is useless. It dead weight in the trunk. I'm afraid to get a flat someday, just want to be prepare just in case.
thanks!
thanks!
I think you will probably need special lug bolts. I hear people get them from a company called RAD. Search my site for "w211 wheels on w210" and "w210 rad bolts" and you should find info you need.
http://www.everythingbenz.com
My stock W210 spare fits over my rear Brembo's (328mm 4piston). There is no way the spare will fit over my front Brembo's and your front brakes are even bigger then mine. My Carlsson wheels are 19-8.5 on all four corners. I figure if I ever get a flat in the front I can always put the spare tire on the rear and then move the rear Carlsson to the front. If your wheels are staggered then this is probably not possible but if they are the same size front and rear this may be your best option.
the w211 AMG spare tire fit over their 8-pot caliper so i figure it will fit over my 6-pot. I would hoping the W211 spare will fit the W210. If not I have to get a extra 19x8.5 front and use it for a spare, but i would prefer the W211 spare because it much lighter.
