Who has the highest mileage car? I have a question for you..
I would love to know who has clocked a few miles on their beasts. I've owned my 2000 E55 for about a year now, and it has 148k miles. Should we consider this a lot? My other question concerns maintenance. In the year that I've owned my autobahn cruiser, I've:
replaced the MAF sensor, the Crank Position Sensor, both of which had left me in ackward positions when they failed. Got both through AutohausAZ
had the gearbox flushed completely at AAMCO, and the rear differential oil changed(I also had a leaky pinion seal).
Changed all four O2 sensors, all 16 spark plugs, and replaced both air filter panels with K&N's.
And a new windshield wiper. And don't forget the countless rear tires.![drive](https://mbworld.org/forums/images/smilies/driving.gif)
My question is what should I expect? I've read about the MAF and CPS, and also about the front ball joints and bushings on the lower front arm, which need changing eventually. My car "clicks" driving slowly into driveways, so I understand the swaybar links need replacement. Not the bar bushings, but the links themselves.
So, post your mileage!! I don't want to be the only one over 140,000 miles. And let me know about your maintenance challenges
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
got a 98' and im up to 176,000...runs fine...minor issues however, had to get 2 new catalytic converters...couple other things...i want to hold on to this as long as possible...
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
98 E320 about 178K on her. Still running, no major problems. The two major issues were the EGR Valve, and the Blower Motor, that's all.
as far as maintainence, before I left NJ for Cali, I replaced the spark plugs, oil change and filter (which I have done once again since being out here) fuel filter, air filters, cabin filter(s), charcoal filter(s) and the serpentine belt.
what do you mean by torque blast?
also while we are on the subject of maintainence, my makes the same clicking sound when going slow over drainage ditches, etc. and IF ANYONE HAS experienced this let me know. sometimes when I go downhill or slow down from high speeds it doesn't down shift. any ideas?
2001 E55K
I have 76k on my '99.....I have had 0 problems with it...and the previous owner had 0 problems with it during the 7 yrs he owned it.
I have done some maintenance to it by my own choice....new serpentine belt, fresh coolant, fresh brake fluid, new battery, all new filters throughout car, oil changes etc...the usual stuff any car at 60-75k would require.
I hope it keeps running this well....
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Used to drive E55
2004 W211 E55K, GL550
Used to drive E55
![Smokin](https://mbworld.org/forums/images/smilies/smokin.gif)
2006 Mercedes E320 CDI
Help
I am brand new to his website, I have regestered but how do I post a question.
Russ
Russ
I'm not sure if the MAF was ever replaced on mine. I bought it with 65K and now it has 80K miles. 2000 E55. can you replace the MAF yourself.
ah yes, when the pedal hits the switch on the floor. that is a good feeling.
rims are brabus monoblock iv replica 19 in off set i belive is 32 in front and 40 in the rear i might be wrong. Ohh and the rear lip is a 4in lip cant tell from the pics but looks great.
SL600
You guys can clean these MAFs rather than throwing them away, you know?
I have an SL600, and each of my two MAFs is $300 on autohausaz, or $582 at the dealer, and so I don't have the luxury of throwing them out every 6 months like some of you do. So like one of Darwin's apes, I've adapted...
Take a soft toothbrush or a Q-tip and some pure alcohol, then remove the MAF assembly from the car and use these implements to thoroughly clean the sensor element. Then, douse it with CRC's MAF cleaner spray just for good measure, and re-install it in the car.
I think you will find the results to be the same as replacing it with a new one.
Thank you CWW that's what I have trying to tell everyone. It takes 40 min top. I cleaned mine while having a Corona..Night and Day bay...What I don't like tho is that I am rocking K&N so I know that I'll have to clean her out ever 15k or so....
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
