A little advice needed....
2000 Mercedes E55 AMG W210
OK, I've had my '00 E55 for around 2 months now. I've had my fair share of performance cars but have had trouble adjusting to this one.
And now I've worked out why...
There is a definate delay between my application of the throttle and response from the engine. This makes the car difficult to drive smoothly, the delay often dumping power to the rear wheels causing the traction control to kick in.
This in turn has also created a lack of confidence especially through fast bends etc.
Is this a well known fault? Has anybody heard of this before? How can I rectify this? Chip?
I know that I have a fantastic car hiding behind this 'glitch' but I'm struggling to find it!
Any help would be greatly appreciated.
DC
DC
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
DC
DC
Assuming that the Engine and tranny are all running fine, the slight delay is typical with these cars , and actually several other Benzes I have owned.
1- If what you are referring to as delay, is actually expecting the car to downshift ( Passing cars ) faster , you might want to reprogram the Transmission, as it is adaptive and probably running on what people refer to as " Granny Mode ! Turn ignition on ( dont start the car ) , floor the gas pedal and hold it for 5 seconds, turn ignition off, then release your foot of the pedal five seconds later/ wait two minutes, then the drive the car hard for couple of miles with heavy downshifting via pedal, tranny will reset.
2- Best throttle response : Sprint Booster AMG version ( best $260 spent on the car.
Hope this helps. Cheers.
Max
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
DC
DC
If you are depressing the gas petal fast and hard enough for the traction control to cut power that is not a delay that is called wheelspinn.
Thanks for the quick response Max.
I keep the gearbox in 'S' mode and it seems to kicks down OK. The delay is more noticeable when pulling away, especially if I'm turning at the time. If I need to get out of a turning quickly nothing happens then the power comes in as I'm mid-turn causing the inside wheel to try and spin and bring the traction control on.
I know this sounds like I'm just flooring it but I'm not. Even if I feather the throttle it still happens.
I think the previous owner drove the car quite conservatively but I do tend to have a heavy right foot. If the gearbox is 'adaptive' as you say, then maybe it will adjust to my driving style in time. I'll try what you recommnded and see how I get on.
Still, if anybody has any further advice, I'm all ears.
Yacht Master, it's not just my heavy right foot I'm positive.
Another point is that the actual accelrator pedal is quite stiff compared to other vehicles I've owned. It also seems a bit 'jerky' in it's action.
DC
DC
OK, these car are fly by wire, the gas pedal should be smooth as silk. You need to check the throttle pot it is located under the hood drivers side (US) to the rear by the fire wall. The pot will have a small cable going to it from the pedal. Have some one work the gas pedal and you will find it no problem. Now check the cable for broken or frayed strands these cables fetch up and bind right before failure, if it looks OK then move to the pot and operate it it through its full range of motion it should be smooth and the only resistance will be the return spring. These are the only mechanical items that will cause a stiff pedal. My guess is the cable is about to go.
Yep W210 FBW, Now that I see you are in the UK, I am not sure what side of the car it will be on. But it is easy enough to find with a helper working the pedal.
Max, the accelerator cable is not mechanically connected to the TB. The gas pedal is electric, and is just one of many inputs the ECU and TCU use to control the TB.
maxwerks, where would I find the AMG Sprint Booster you talk about.
Also, is it a simple plug-in or does it require professional installation?
I'm in the UK remember so may have to have it sent across the pond.
DC
DC
No worries maxwerks, I've just found it a CKS Performance. I'm up there way next week and will try to book it in and have one fitted.
Thanks for all the info anyway. Will see if this sorts it out.
DC
DC
