Strange Check engine/SRS light problem
Fuel Trim Bank 1
Fuel Trim Bank 2
and Transmission Control Electric
The car sat for less than a hour and when I started it back up... no CEL.
The same thing has happened again, with the light coming on for a few hours and then is off when I restart the car.
In addition, each time this happens my red SRS light comes on and sometimes stays on, and other times will flash on and of randomly.
I did some searching for the CEL codes and found that some people have this type of problem when their battery is close to dead... They say before buying a new MAF or cleaning the current one (to fix the fuel trim light) that I should try replacing the battery. The people who had the issue had the factory battery and most were 6-7 years old.
The car feels perfect and doesn't feel any different when the lights come on..
Any thoughts? ideas?
Thanks!
Press and hold rest for 5 secs, use right auto button and toggle to screen 24. Press rest or turn key off to exit.
Should read +13v.
I'd ignore the 715 trans code, absent shifting issues.
PO170/172 are fuel trim and are set by rich/lean conditions or "perceived" conditions. The air side of things CAN be a dirty air cleaner, the MAF and/or O2 Sensors.
Am not conversant with gassers fuel metering as am more into diesel and injection pumps.
A MB laptop with SDS could look at fuel trim and live adaptation values and determine what device is no longer able to adjust sufficiently to bring trim into spec.
The fact the CEL goes off tells you it is an intermittent problem that makes this more difficult to resolve.
