19 Inch AMG CL rims
19 Inch AMG CL rims
Greetings everyone,
I have a '02 E55 and was thinking of buying the AMG 19inch Cl rims. I know someone on this board had them. Everything on my car is stock right now. If I buy these I know that I will have to buy spacers for them. Do spacers effect the way the car rides or gets aligned? Any help with this would be much appreciated. Thanks all and happy holidays to everyone.
Ben H
Ben H
Thanks for the compliments Ben! Got them from Peter at www.wheelexperts.com
Originally posted by BenH
JamE55,
are your rims polished all around? I am considering the HRE 547r or 543 r's. I like how yours look. Are they all polished or just the lip?
Thanks,
Ben H
JamE55,
Thanks,
Ben H
My wheels are not polished all around. I don't like that mesh full polished looks. It looks like it's chromed so i opted for a aluminum brushed finished. The lips are however full polished and i love them! Don't think you can go wrong with 547R's or 543R's. I like the 540R's just because of that racing mesh look.
Originally posted by E55 KEV
The wheels for W220 & W215 use 14mm bolts and the W210 has 12mm. So they would not fit.
JamE55,
did you have to change anything to make the 19 x 10's in the rear to fit? or are the 19x9 and 19 x10 rims fine without any mods?
thanks and Happy New Year.
Ben H
JamE55,
Ben H
No changes on the current setup 19x9F and 19x10R. Using the correct measurements Peter did on my wheel everything came out exactly as planned. No fender rolling and no spacers needed. Hope this helps.
Happy New Year to you too!
2016 GLE63s / 2016 E63s / 2002 E55
That front setup Jam is using up front (19X9) is a miracle to me. I tried to use 18X8 et35 wheel (OEM 18X8 et31) with a Nitto 555 245/40/18 and it rubbed inside. The Nitto does have a wider shoulder than others same size. I put the 245/40/18 Dunlop 9000s back up front and it is so close that some occasional rubbing occurs during parking when the wheels are turn to lock when the suspension is compressed.
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Originally posted by JamE55
It's not a miracle KEV is HRE!
I had Brabus Multi V 9.5's in the front on my E55 with no rubbing.
Administrator
Vic,
with the 10mm spaces, did you have to do anything else? or just add the spacers?
Ben
Vic,
Ben
Originally posted by Vic55
I had the hubs on the wheels machined to I believe 68.5mm to match the axle hubs. I then had the spacers done so we could use the correct bolts and the tires were pushed out to the fenders.
Vic, did you also use a spacer with the 9.5 Brabus wheels up front? What offset? Thanks.
Administrator
I thought all Mercedes wheel hubs were the same - 66.56? What wheel uses the 68.5mm hubs? Thanks.
