how should e55 w210 engine sound?
Old May 6, 2009 | 04:17 PM
LeeRod80's Avatar
99 E55 AMG
Originally Posted by amgalex
anyways back to the original topic:
Im 100% positive the engine is making less noise. Im thinking its because of gunk built up that might be related to slow driving of the previous owner and 15,000mi oil changes . After my driving aggressively gunk came loose and the noise stopped.
I just cant figure out why it stopped after an oil change after only 2000mi on fresh oil..
Can you give a step by step on the Sea foam process, please?
Old May 6, 2009 | 04:46 PM
amgalex's Avatar
00 e55
use vacuum tube from brake booster, with car idling, slowly let the vacuum suck about half of can inside the tube, turn of the engine wait 7 minutes, start car let idle 5 minutes, go for a spirited drive.
Old May 6, 2009 | 04:52 PM
LeeRod80's Avatar
99 E55 AMG
Thanks! Where can I buy the can-o-Sea foam?
Old May 6, 2009 | 11:31 PM
Fabio D's Avatar
210 55
Originally Posted by nick 55
It's actually 24 pounds of lead encased in rubber to "dampen chassis vibrations". The 124 cab had that and another one in the floor of the trunk....not like it helped much, you could still see the windshield header shake when you hit bumps.
Nick
Good explanation my friend! i understand now! ya, right the windshield have the same problem for the E36's cabrio
Thaks a lot.
Fabio Daniel
