How many e55 owners have a slight shaking at idle?
I got an 00 with 106k mi
car shakes slightly at idle
Is this a common problem?
what can be causing this?
I do have new motor mounts and spark plugs installed so thats not the cause.
well my car have the same 3 month ago, i replace tha spark plugs & made an ultrasonic clean on my fuel injectos, change the fuel filter & the car run smothly again!
Hope that help
Fabio Daniel
Hope that help
Fabio Daniel
Every older NA 55 I've gotten into has had the shake. Adding a full can of seafoam into half tank of gas definitely helps get rid of alot of the vibration but it does not cure it over the long run. It can be anything from MAS to bad O2s to plugs/wire to dirt injectors to bad mounts. Best way is to just move systematically from the cheapest maintenance option to the most expensive until its cured.
Mine is opposite, when it cold it so run so smooth you wouldn't know the engine is running.
Even when it warm as lone as it in drive it very smooth but once you put it in park the engine vibrate/shake
