New Toy to show off
3000 miles, like new!
Transmission 6-Speed Manual
Exterior Black
Interior Black Full Leather
Engine 6 cyl.
3.6 liters
Rear-mounted BiTurbo engine with Vario-Cam Plus
Twin turbochargers with variable turbine geometry (VTG), twin intercoolers
Power 480 hp (353 kW) at 6,000 rpm
460 lb-ft (624 Nm) at 1,950 - 5,000 rpm
Drivetrain All-wheel drive
Brakes 6-piston (front), 4-piston (rear) monobloc fixed alloy calipers and ventilated brake disks.
Brake calipers painted in red
Anti-lock Braking System (ABS 8.0) with Porsche Stability Management (PCM)
Equipment
Features 3.6 Liter Flat 6 cylinder BiTurbo engine with Vario-Cam Plus producing 480 Horsepower.
Twin turbochargers with variable turbine geometry, twin intercoolers.
Dry sump lubrication with external oil tank.
6-speed manual transmission with dual-mass flywheel and hydraulic clutch.
All wheel drive with Porsche Traction Management (PTM).
Anti-lock Braking System (ABS 8.0) with Porsche Stability Management (PCM).
Braking system with 6-piston (front), 4-piston (rear) monobloc fixed alloy calipers and ventilated brake disks.
Porsche Active Suspension Management System (PASM).
Tire-Pressure Monitoring System (TMS).
19-in Pressure-cast alloy Turbo wheels.
Brake calipers painted in red.
3-spoke sport steering wheel (Diameter 370MM) in leather with full color Porsche crest.
On-board computer with continuous indication of mileage, time, speed and pressure gauge.
Electrically adjustable seats (driver and passenger side) including lumbar support and integrated airbags. Memory function driver side.
Outside mirrors are electrically adjustable and heated.
Automatic extending rear spoiler.
Aluminum doors and trunk lid.
Bi-Xenon lighting system with headlight leveling and washer system. Separate lights in front apron with led-indicator and fog lights.
Porsche Side Impact Protection System (POSIP).
Front seatbelt pretensioners with belt-force limitation.
Alarm system with radar interior surveillance.
Sunroof.
Interior parts in aluminum look, shift lever with Turbo design.
Full leather interior in standard colors.
Automatic full climate control with active carbon filter.
Dual cup-holders integrated behind decorative molding in dashboard.
PCM with 5.8 inch color display, GPS navigation module, in dash CD and sound package which includes 9 loudspeakers, Bose surround sound.
Intermittent wipers with rain sensor.
Homelink system.
Cruise control.
Additional
Equipment 342 - Heated Front Seats
EAA - Leather Package Switch Panel
XNG - Instrument Surround in Leather
CDZ - Gear Lever Trim in Leather
XXZ - Foot Rest Aluminum
CPA - Thicker Leather Steering Wheel
635 - Parking Assist System
431 - 3-Spoke Str Whl Multifctn lthr
CXB - Door Entry Grds Stl Steel Illu
CGA - Headlight Cleaner Cvr Ext.Clr
220 - Axle-Differential Lock Rear
640 - Sport Chrono Package Turbo
XMZ - Rear Center Console - Leather
P01 - Adaptive Sport Seats
Notes Power Door Locks, Power Windows, Alloy Wheels, Tachometer, Air Conditioning, Cruise Control, Rear Defroster, Power Driver's Seat, Power Passenger Seat, CD Player, AM/FM Radio, Power Mirrors, Spoiler, Leather Wrapped Steering Wheel, Steering Wheel Controls, Heated Seats, Certified Used Car, Leather/Leatherette, Sunroof, Warranty, Fog/Driving Lamps, Bose Sound System, Home Link
Exterior Black
Engine 6 cyl.
3.6 liters
Equipment
Sunroof.
Homelink system.
Cruise control.
Additional
Full size spare?..............................J/K !
I may just have to take a peek at this next time I'm up in your neck of the woods. Can't say I've ever considered a P car, waiting until I hit the quarter century mark and insurance premiums drop before I even look halfway serious at one.
Just kidding, very nice and congrats.
If you aren't already on rennlist, hop on over...http://forums.rennlist.com/rennforum...rbo-forum-139/
stop by anytime and take a test drive
You would only save $900 if you can avoid the blue and red.
