best performance intake for w210 e55 amg
cheers
When I did mine unique tune, the tuner allowed the MAF to give the engine more air, and if you combine that with a better flowing intake you will get more power and torque.
Also should say that all small parts count, so lets say a couple of headers,exhaust and ECU will most likely let the new airbox to do a better job then a stock airbox.
Have you tried switching back to the stock W210 to compare, post tune?
This is an old thread you are looking at. Anyway, I would recommend, besides getting the RennTech Carbon Fiber "bubble butt" airbox, the other route would be to gut out the line of plastic fin looking things in the OEM box and smooth it out. Throw in a pair of K&N filters and you could get some mid range hp and torque as the air is not as restricted without the fins. You can use a Drummel cutter to cut them out and sand down the cover.
good any dyno numbers to compare ?
