my own bottle cap Sprint Booster
Old Apr 29, 2009 | 11:17 PM
amgalex's Avatar
00 e55
Well after doing a little bit of research on what Sprint Booster does I have came up with my own no cost design to help with lag and increase throttle response.
Get a 2 liter cola plastic bottle cap,( fits perfect for what we need), some scotch tape. Tape the cap directly unto the kick down button under the gas pedal.
Since throttle is controlled not by wire but electronically you must do the transmission reset so when the kick down is pressed throttle signal will read at 100% ( verified by an obd 2 reader)
Now the ecu readjusts the gas pedal range so 100% throttle is closer than before and whalla, my own sprint booster
results: less lag, more aggressive throttle
Don't believe me?
try it yourself and post back the results..
Old Apr 29, 2009 | 11:31 PM
LeeRod80's Avatar
99 E55 AMG
You're crazy....
Old Apr 30, 2009 | 12:57 AM
amgalex's Avatar
00 e55
I was not joking
someone else try this to confirm my results
MR888's Avatar
E55
Since throttle is controlled not by wire but electronically you must do the transmission reset so when the kick down is pressed throttle signal will read at 100% ( verified by an obd 2 computer)
Don't believe me?
Hrmm, I hope this is a joke.
Old Apr 30, 2009 | 01:00 AM
MR888's Avatar
E55
I was not joking
why in the world would you want to have the kickdown pedal depressed with a light foot? its only good for serious passing or serious acceleration otherwise its gonna be just jerky, don't knock the sprint booster untill you try it this thing is no joke
amgalex's Avatar
00 e55
lol
Im dead serious.
Iv been driving around with the cap on the switch all day long today
Old Apr 30, 2009 | 01:06 AM
amgalex's Avatar
00 e55
Originally Posted by MR888
lol then you are not too bright , why in the world would you want to have the kickdown pedal depressed with a light foot? its only good for serious passing or serious acceleration otherwise its gonna be just jerky, don't knock the sprint booster untill you try it this thing is no joke
like i have explained before, I think the ecu readjusts to new decreased operating range.
Most new cars ecu's can be reset this way to learn operating range of the gas pedal.
Car is not jerky at all and I'm not knocking the spring booster, its just an experiment here but I think it actually works
thats why I want someone else to try this
Old Apr 30, 2009 | 01:10 AM
MR888's Avatar
E55
hrmm wait so its only a bottle cap? I misread your first post lmao, I thought you taped on a bottle inbetween the pedal and would of had the kickdown hit every time you gas it just a cap seems ok i guess
Old Apr 30, 2009 | 01:12 AM
amgalex's Avatar
00 e55
lol
did you think it was the bottle??????
lol
Old Apr 30, 2009 | 01:18 AM
amgalex's Avatar
00 e55
kick button engages 1" sooner and looks like range of the gas pedal got decreased by looking at my obd2 computer. 100% throttle as soon as the button is pressed even though gas pedal does not go as far down as it did before.
Old Apr 30, 2009 | 01:45 AM
MR888's Avatar
E55
do you get better response in the pedal range before kickdown?
Old Apr 30, 2009 | 01:49 AM
amgalex's Avatar
00 e55
Im not sure, although it feels like response is better before the kick down as well which would make sense if ecu readjusted the range.
Old Apr 30, 2009 | 01:56 AM
MR888's Avatar
E55
Get the Sprintbooster and you will be SURE! lol this thing is nuts
Old Apr 30, 2009 | 02:12 AM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
Is anyone else tempted to try this... just to see if it will actually work?
Old Apr 30, 2009 | 02:17 AM
amgalex's Avatar
00 e55
I say definitely try it, don't cost you nothing just 10 min time
just please post back the results, thats the only way we can all learn something.
Old Apr 30, 2009 | 08:18 PM
saintz's Avatar
GL450
Having just replaced my throttle position sensor and relearned the ECU, I am inclined to believe this will behave very similarly to a sprint booster. The only real possible difference is this remaps your throttle linearly (effectively just decreases throttle range and increases throttle sensitivity), whereas the sprint booster, at least in theory, could apply a non-linear mapping (although I highly doubt it does).
Maybe someone with a Sprint booster can disconnect it and try this to confirm if it works similarly or exactly the same.
Old Apr 30, 2009 | 08:54 PM
MR888's Avatar
E55
Im thinking about it, and there is no way this can work like the Sprintbooster, ok you have a bottle cap on the kickdown, but that means you will have to hit the kickdown atleast a good few times a day for the ecu to remember the settings, and living in a city kicking down is not really an option on the streets, the SB works as soon as you touch the pedal and never forgets its settings. All this said we are assuming the ECU even recalibrates the pedal range which I doubt it does in the first place, so im pretty sure this whole idea is BS, the only benefit is you will hit the kickdown earlier, with no effects in the pedal range before that.
Old Apr 30, 2009 | 09:48 PM
LeeRod80's Avatar
99 E55 AMG
Will hitting the kickdown almost everytime you use the throttle damage anything?
Old Apr 30, 2009 | 09:55 PM
armaniE55's Avatar
2012 CLS63 AMG
No but it's unnecessary stress unless your in a rush to get to MCaDee's
Leerod I posted a few pics on the other Thread
Old Apr 30, 2009 | 10:23 PM
saintz's Avatar
GL450
The stock electronic throttle appears to be able to recalibrate itself. This is different from cable based throttles. If anyone with a Sprint booster wants to test it, I would once again suggest comparing.
Old Apr 30, 2009 | 11:32 PM
amgalex's Avatar
00 e55
You will not hit the kick button each time you accelerate, it will be a little easier to hit with the cap on but you will still only hit it when you floor it.
Old May 1, 2009 | 12:01 AM
LeeRod80's Avatar
99 E55 AMG
But, when you kick it down.. theres still a delay (lag) before it goes full throttle.
Sprint booster...almost NO lag at all..
Old May 1, 2009 | 12:06 AM
amgalex's Avatar
00 e55
yes the shift lag is still noticeable but I did not think that Sprint booster eliminated that issue, did it?
