Front suspension noise/new wheels
Old May 4, 2009 | 10:33 AM
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
Well, i finally got around to putting on the new wheels this weekend that I got for very very cheap. Once i installed them my front right suspension knock went away, for a while. I usually get a knock over bumps or imperfections on the road. I've had the car on a lift a couple of times and the sway bar end links look a little worn but nothing too bad. Both sides look the same so I "assumed" that was not it since the knock is only on the right side. I've changed the ball joints but it's still there.
Anyway, since the noise went away for a while once I jacked the car up to put the wheels on, i'm wondering if it is the shock or spring? The car does what it should but it has that very annoying knock that is driving me nuts.
I've taken it to a reputable indy and he told me that with these types of noises you just have to start changing parts out until it goes away, which is something I don't want to do.
Any ideas?
Attached Thumbnails Front suspension noise/new wheels-img_3646.jpg   Front suspension noise/new wheels-img_3644.jpg
Old May 4, 2009 | 05:32 PM
MR888's Avatar
E55
Not bad looking wheels, you should consider lowering it a bit though, btw I had the same type of knock, I thought it was my shocks as well, but I changed the sway bar links as the first thing and that was it 20$ part, the old ones can look FINE, but the inside bushing is finished so just change these first and see if it helps.
Old May 5, 2009 | 08:59 AM
nicobaires's Avatar
I've been meaning to lower it and probably will, the only thing stopping me is that my driveway is so freakin steep that if i don't angle it right it scrapes the *** as it sits now!
I will do the sway bar links and report back, thanks
Old May 5, 2009 | 01:30 PM
zmirza's Avatar
02 E55
what size tires do you have on? Are those 19's?
Old May 5, 2009 | 01:34 PM
nicobaires's Avatar
yeah, 19's
245's in the front and 275's rear
Old May 5, 2009 | 02:33 PM
LeeRod80's Avatar
99 E55 AMG
I have a slight clank/knock coming from my driverside front when I hit bumps with window open only.
I'll be lowering my car this week, so I decided to replace the sway bar links and maybe control arm bushings while it's in the shop. They guy quoted my $150 for the links. Does that sound reasonable?
I asked him to give me the GRAND total for; Shocks & Springs install, alignment, sway bar links, and possibly control arm bushings if needed.
Just waiting for a call back. It's a repituble shop, so I know they'll do a great job.
Let me know if theres anything else I should look at, while they're working on the front anyway? I want a nice tight ride.
P.S. Sorry for the thread highjack.
Old May 5, 2009 | 04:08 PM
zmirza's Avatar
02 E55
Originally Posted by nicobaires
yeah, 19's
what size profile
I am in the process of ordering Good Year F1 tires and I am getting confused as people are recommending different sizes
235/35/19
275/40/19
The other guy is advising:
245/35/19
275/30/19
I would really appreicate your input.
Old May 5, 2009 | 04:16 PM
nicobaires's Avatar
I'll look after work, whatever i have there is no rubbing at all
Old May 5, 2009 | 04:53 PM
MR888's Avatar
E55
Originally Posted by zmirza
what size profile
235/35/19
275/40/19
245/35/19
275/30/19
245/35/19
275/30/19
that is the correct size.
Old May 5, 2009 | 06:06 PM
zmirza's Avatar
02 E55
Thanks!!!
Old May 5, 2009 | 06:38 PM
nicobaires's Avatar
245/35/19
275/30/19
thats exactly what i have
Old May 7, 2009 | 01:06 AM
SleepersRock's Avatar
2008 W211 E63
I
Do you get knocking sound when you brake sometimes too? I hear a clank/knock when I brake especially after a hard acceleration.
Old May 8, 2009 | 09:17 AM
nicobaires's Avatar
No knocking when braking for me
Old May 8, 2009 | 11:15 AM
LeeRod80's Avatar
99 E55 AMG
No knock while braking here either.
Old Aug 17, 2010 | 12:13 PM
MR888's Avatar
E55
I have this knocking again, but it sounds worse then the sway bar links this time, arr, just changed the ball joints but its still there, what other parts are known to go bad in the front?
Old Aug 17, 2010 | 02:25 PM
nicobaires's Avatar
My original noise was a bad shock, but now i have all kinds of clunking noises coming from the front. It goes away when I am braking, most of the noises. My calipers don't have the brake pad clips intalled. I installed them once but they fell off after a couple of miles and I have been meaning to put them back on the right way for some time now.
But I think there is more to it than the clips. My rear end is also making some metal noises when I go over bumps.
Very annoying
Old Sep 14, 2010 | 04:08 PM
Mr.Biriggwa's Avatar
2002 W210 E55 Corporate Land Jet
Very annoying
on the rear, I would check the sway bar bracket. I had the same knocking whenever I went over bumps. One way to check is to put the car on a lift and pull on the sway bar. If its off its bracket it will hit your lower control arm. Just my .02
