inputs on DEPO PROJECTOR headlights
Old Sep 21, 2009 | 02:18 PM
pinoyk20's Avatar
99 model w210 e55 amg
hi guys! can you pls give me inputs on the DEPO PROJECTOR HEADLIGHTS..
what are the pros and cons of using one for our w210 e55? thanks
Old Sep 21, 2009 | 03:44 PM
BJAFARI93's Avatar
W210
i actually just ordered a set of depo headlights (halogen) and also installed hid fogs and low beams. I followed ohlords advice before and polished the lens and installed the brighter bulbs but my lighting was still poor. Now the lighting is great, cutoff point is perfect, and the car looks so much better. Let me know if you want i can post up pics (my car looks very similar to a 99 e55/black). Also make sure you buy them from the guy that clarifies they are depo, i had a set before that looked the same but were terrible
Old Sep 21, 2009 | 03:46 PM
saintz's Avatar
GL450
This might get you started:
https://mbworld.org/forums/3682959-post3.html
Basically, Depos will not work well with the HIDs that (I'm assuming) you have on your E55. You either need to convert to halogen with the Depo, or you (ideally) need to cut open the Depo and retrofit a pair of HID projectors as detailed in this post:
https://mbworld.org/forums/e-class-w...tor-retro.html
Also check the classifieds, there may be a modified pair for sale.
Old Sep 21, 2009 | 04:03 PM
MR888's Avatar
E55
Just get an H7 HID kit and you are good.
Old Sep 21, 2009 | 05:49 PM
BJAFARI93's Avatar
W210
exactly, light output will still be great
Old Sep 21, 2009 | 11:05 PM
desired_speeds's Avatar
2007 SL55 AMG
No it won't.
Picture taken from here: https://mbworld.org/forums/e-class-w...tor-retro.html
Old Sep 22, 2009 | 12:30 AM
MR888's Avatar
E55
Originally Posted by desired_speeds
No it won't.
wtf is that, my output looks nothing like that, mine is spread out even and I got the DEPO's with an H7 kit.
Old Sep 22, 2009 | 04:19 AM
Silver Logic's Avatar
W210 E55 AMG
pinoyk20,
Aren't you happy with your 8000k's conversion?
Old Sep 22, 2009 | 11:44 AM
pinoyk20's Avatar
hi alvin im hapy with it im jsut looking for other options. i want to try the smoke prjector headlamps if it will look good with the carbon fiber hood
Old Sep 22, 2009 | 03:08 PM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
I have the depos in my car with Bi-Xenon audi projectors and the lighting is phenomenal. I have 6000k HID with it and on low beam the visibility is excellent. And on high beam, haha dont even get me started. Let me just say my high beams light up entire houses, and even light up tree tops. It is sort of a pain in the *** to do the retrofit, but after its done, the result is no less than spectacular.
The depo's original projector blows complete *** as the people above me have clearly discovered. Especially if you are using HID's. Unless your using a halogen bulb, don't waste your time with depo's if your not going to modify them. they sure look cool and everything but you probally would have better lighting with the OEM headlights and hid's. (Not that im recommending that)
Old Sep 23, 2009 | 12:12 AM
pinoyk20's Avatar
thanks for the infos.
