Oil leak in engine
What are the odds of our gaskets failing?
Also I see now coolant in the oil or loss of power of any kind. Just oil loss.
Is it actively dripping, or just dirty/oily? If it is noticeably dripping, you'll need to replace them. If it's just wet, and the oil level doesn't drop quickly, you're probably ok. First, determine if it's the breather (on top of the valve cover) or the valve cover itself. See if the bolts on the valve cover are loose, and if so, tighten them (but not too tight). If that doesn't help, you can replace the gaskets.
Gasket available on autohaus folks
Thank God it's not the head gasket!!!
In theory you should use a reverse torx bit (star shaped socket). However, a standard 6 point socket will work since it doesn't take a lot of torque and you shouldn't strip the bolt. It's something like 10, 12, or 13 mm. Basically, any metric socket set will work. You want to torque it gently (probably in the 15-20 lbs-ft range) so you don't damage the bolt or the engine head. Just go for snug.
What is the sequence to tighten the bolts and the exact lbs/ft?
someone with the WIS should look up the torque spec for you.
, they have everything you need. Most likely valve cover gaskets, its not too major of a job. Be happy its not your head gaskets.
