Very interesting information for all those with low power concern, slow w210 e55
Old Mar 16, 2010 | 09:00 PM
armaniE55's Avatar
2012 CLS63 AMG
Definitely a one off wouldn't hurt to PM Ohlord, I PM'd him a few times on some stuff even spoke to him a few times over the phone really nice guy. I also had him ship me a floor shifter along with a tool box to remove radio, climate control and cluster at a great price.
He's the Guru for W210
Best advise I can offer, he may also be able to get you a used ECU I know he has a lot of connections for parts.
GL!
Keep us posted
Johnny
Old Mar 17, 2010 | 01:22 AM
amgalex's Avatar
00 e55
GL!
Keep us posted
Johnny
K thanks for the tip...
I was told its got be be programmed vin spacific one time use on a new ECU only, used can not be reprogramed Dealer won't do it
Either wa thank for advice Il pm that guy..
Old Mar 17, 2010 | 10:37 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
How is the compression on all the cylinders? Was that chkd? A slightly bent or a burnt valve could cause similar issues as well. This of course would be a worse case scenario.
Old Mar 24, 2010 | 04:04 AM
amgalex's Avatar
00 e55
No Compression was not checked because vehicle has plenty of power after the reset but after that ecu pulls fuel out... so it can't be Bad compression can it and have full power after reset ?
Old Mar 24, 2010 | 02:58 PM
kaiser_soze's Avatar
2001 E55 AMG
I had a similar problem with my 01 E55. I noticed the power just wasn't there. Every time they flashed it, it felt like she woke up and was ready to go. Within a day it would settle back into an almost lazy feel. I replaced Air Mass Sensor, didn't help but they said it needed it because idle was poor. The only time I ever got to see what this car is really capable of is after it's flashed. The dealer acted like I was crazy. The answer I got was AMG's being hand built, are all a little different, some are really responsive and others aren't, yours is just on the slower side of the spectrum. I was pissed. I felt like, "then where is the one I paid for"?!
I never replaced the ECU and have no plan to spend the money to do that, the car is still faster than 90% of whats on the road, but it does still frustrate me at times.
Old Mar 24, 2010 | 05:30 PM
amgalex's Avatar
00 e55
Haha yea Dealers are asses they act like there is nothing wrong when clearly car isnt running right , independent mechanic confirmed that ECU is doing wierd things and is narrowing injector pulse instead of widening it at load and is way lean,
now there is even a service bulletin on this problem but dealer still has no clue or do they?,, what is going on here? Mercedes just don't want to face the problem or what?
Buy an obd2 reader, they are cheap and watch your O2 voltages at load and see if they go way lean to confirm a defective ECU issue...
Old Mar 26, 2010 | 08:44 AM
  #32
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
I doubt its you ECU. Even though the Motronic has an idle circuit your problem sounds like issues the other posters mentioned.
Sounds to me like clogged injectors or a faulty fuel pressure regulator .
Besides if your ECU was bad your car would be in limp mode and you wouldn't even be able to do a 0-60 run.
Easiest start for diagnosis is to borrow a known working ECU to swap in.
Maybe you can Paypal someone a refundable deposit to insure a return.
If anyone does lend him an ECU, make sure you mark your box w/ your name as well as breach-tape.
I got burned once....so speaking from experience here.
Good luck.
Old Mar 26, 2010 | 11:36 AM
  #33
amgalex's Avatar
00 e55
Good luck.
These UCU's are Vin Specific , you can't just stick one from another car, it won't work.
Old Apr 20, 2010 | 03:13 PM
  #34
amgalex's Avatar
00 e55
Ecu coming ,,crossing my fingers....
Old Apr 20, 2010 | 04:43 PM
  #35
armaniE55's Avatar
2012 CLS63 AMG
Really? How much? Will you have to go to the Stealer to swap it out? and re-program
Armani GL!
Old Apr 20, 2010 | 04:50 PM
  #36
amgalex's Avatar
00 e55
I just found a used one for 250,,, so il
try that first but im pretty sure il need it reprogramed to match my vin, found a company that can do it for $450
Old Apr 20, 2010 | 07:48 PM
  #37
mysticblu999's Avatar
Mercedes AMG
Old Apr 22, 2010 | 05:19 PM
  #38
ProjectC55's Avatar
Old Apr 30, 2010 | 01:34 AM
  #39
austin814's Avatar
C280, E55, CLK430, E550, Toureg
If the ECU is supposed to tune the engine to how you normally drive wouldnt leaning out the fuel for someone that drives very smoothly be normal? I'm a very smooth driver (except when a Mustang or Infiniti needs a lesson in what a Mercedes is) and my E55 has 22.8MPG over the last 3000 miles. My last 200+ mile trip it was up to 25.3mpg (trip) at best and was at 24.8MPG as I was backing it into the garage. I would think if you drive like this normally you cant expect to have the ECU be tuned for both high MPG type driving and high HP. Still even a "slow" E55 is a beast on the interstate, it has torque all over the range. It will be interesting if a new ECU has a software update that can make it be both but it seems to be that a learning ECU would work on a basis of past usage. So when you surprise it by pushing on the gas and that isnt something that is a normal occorance its not going to pour gas in because that isnt something you normally ask it to do.
My thought on how they could program around this would be that the shift down button under the gas pedel could signal the ECU to ignore its learned behavier until the pedel is returned to a normal range.
Waiting to see how this turns out...
Old Apr 30, 2010 | 01:58 AM
  #40
amgalex's Avatar
00 e55
actually after the power loss and ecu running lean is when I get the worst MPG so this is not what the ecu is trying to do. Its just being stupid , overly sensitive to certain sensor inputs or just plain wacky,, and im thinking the last one is the problem.
Old Apr 30, 2010 | 06:27 PM
  #41
amgalex's Avatar
00 e55
ok i just decided to try the new ecu in the car
nothing happened just as expected the car didn't start so now i need to send both ecu's so they can copy vin information form my old unit unto new and I don't have another car to use so for now im stuck
Old Apr 30, 2010 | 06:30 PM
  #42
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
What's the ETA on this project?
Armani
Old May 1, 2010 | 02:10 PM
  #43
amgalex's Avatar
00 e55
Armani
well now I need to borrow a car for a week . Anyone has an extra car in South Dakota?
o wait,, no one lives here,, almost forgot..
Old Apr 11, 2011 | 06:39 PM
  #44
amgalex's Avatar
00 e55
So Finely after a long long cold winter.
I have sent both old and the new ECU to get them reprogrammed...
Here is the kicker; we had rain last night, when I was taken my ECU out today I noticed a drop of water on the ground , turned the ECU around and half of it is covered in water droplets like really bad condensation..
This must be what semi-fried my ECU.... How the heck did the water get in?
Now I know why my car was running extra rough when it was raining .......
Old Apr 11, 2011 | 08:23 PM
  #45
Schweinhund's Avatar
W210 E55
amgalex,
I seriously do not think your ECU is the problem. Mine requires a reset after about a week and if not, the power drops off over time. The ECU would either work or it wouldn't. They are too complex to be slightly "out of tune". Water would not cause a power loss, it would cause a full failure.
If your car has "full" power after reset, your problem is not mechanical. If it loses power sooner than a week, I would then look for a bad sensor somewhere. Check fuel pressure, check injectors. Check out "wearable" or reasonably failing items. Something that would cause the ECU to go off of its aggressive factory tune quickly. Something out of whack but not enough to throw a code.
Old Apr 11, 2011 | 11:36 PM
  #46
Tikolx333's Avatar
Old Apr 11, 2011 | 11:51 PM
  #47
amgalex's Avatar
00 e55
Originally Posted by Schweinhund
amgalex,
did you read the pdf dealer bulletin?
Old Apr 12, 2011 | 12:09 AM
  #48
austin814's Avatar
How often do you get your car above 5K rpm? I had a coil pack that needed replaced but would not throw a CE code unless it was being driven very aggressively. The code was a misfire code. The first time I reset the code thinking it could be a fluke, second time I replaced plugs and wires, third CE light and I replaced the coil. After the CE light came on the car had what seemed like 1/2 its normal power until it was restarted. Replacing the coil fixed the occasional lurching, occasional hard start and the rare CE light. This was all over a 18 month period.
I don't think the ECU is the problem, you've got something like I did that isn't far enough out of spec to throw a code but not just right either.
Old Apr 12, 2011 | 12:20 AM
  #49
desired_speeds's Avatar
2007 SL55 AMG
how about random misfire from cylinder 4,5,7, and 8? I'm getting it. Doesn't throw any codes, lights, etc. no power loss, its not the spark plugs, coil packs, nor wires. Already tried new MAF, maybe going to replace CPS next. Any ideas guys?
Old Apr 12, 2011 | 12:24 AM
  #50
amgalex's Avatar
00 e55
if you guys read i replaced just about everything in question, including brand new coils, spark plugs and wires
I almost bet im not the only one with water on the ECU, Check your ECU after the rain....
