Key Fob Range
Old Apr 5, 2010 | 05:38 PM
rocketflyer's Avatar
E55 AMG (w210)
Key Fob Range
It seems like my Key fob will go 15-20 feet max, sometimes i need to be even closer or like right next to the car for it to work..
changed the battery, helped a little but range is still terrible..
is this normal? can i replace the key fob with a newer model such as this one:
also, does the remote do any tricks like closing the sunroof or windows?
Old Apr 5, 2010 | 05:59 PM
saintz's Avatar
GL450
You can change key fobs, at least between the W210 all plastic version and the newer style like you posted, so long as the buttons are in the same position. Buy a used one on eBay, take them both apart, and switch the circuit board from your remote into the new "shell."
If you hold the lock or unlock button and point it at an IR sensor (the little black square on the door handle) it will close or open (respectively) the windows and sunroof. You have to hold for several seconds.
If the range is really bad, it's probably only using IR and not RF. Cover the IR emitter on the remote (the little circle on the front) with your finger and try opening the doors. If that doesn't work that will confirm that it's using IR. The fix is to get behind the C pillar on the driver side and fuss with the antenna and amplifier that is back there. If you jiggle it, it will probably get a better connection.
Old Apr 5, 2010 | 07:45 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
man didnt know know you could swap themout .thats pretty kool. have you done it personally ? Is it hard or just plug n play?
Old Apr 6, 2010 | 12:35 AM
SleepersRock's Avatar
2008 W211 E63
Gonna have to try that auto window roll down. Only thing I thought it does open the trunk.
Old Apr 6, 2010 | 08:04 AM
saintz's Avatar
GL450
So long as the buttons are the same layout, it will probably work, so you have to check your key and the one you're looking to swap. I've swapped key shells before. It's fairly easy, but it's a little nerve racking pulling the circuit board out with pliers.
Old Apr 6, 2010 | 05:20 PM
E55 AMG (w210)
this is awesome information.. thanks! will fiddle with it this weekend.
it's really annoying when i cant remember if i hit lock or not and then i have to turn around and walk back towards the car while pushing lock a thousand times until the lights blink.
Old Apr 6, 2010 | 08:49 PM
Fabio D's Avatar
210 55
I think you can swap key shells but same style.. the newer crom style do not match the older circuit board
Fabio Daniel
Old Apr 20, 2010 | 06:02 AM
dababor's Avatar
2001 E55, 2008 S550, 1995 BMW M3
I swapped mine out.. if you get a shop discount its like $90 programmed. It sucks, I literally have to be infront of the car sometimes for it to work.. security feature maybe? The windows up and down is a great thing to play with.. I use it a lot!
Old Apr 22, 2010 | 12:58 AM
mysticblu999's Avatar
Mercedes AMG
You can just order a new key from dealership, and you will get the nice shiny new one.
Stick the key in your mouth. I promise you, It will get better range!
Old May 7, 2011 | 02:25 AM
JuNe LoC's Avatar
LoL Its Funny U Say That My Uncle Used 2 Always Tell Me 2 Hold It Under My Chin Somethin Bout Static Elec.
Old May 13, 2011 | 12:28 PM
AMG_Drvr's Avatar
2008 E63 AMG
Neck, chin, really any part of your body/torso will work. Works like a champ when I don't feel like walking back to the car.
Old May 13, 2011 | 01:36 PM
mfletch69's Avatar
1999 E55
Had no idea. Just tried it...That is kick ***!
