High RPM engine misfire!! HELP
Old Aug 19, 2010 | 11:47 AM
phil55's Avatar
2001 e55
Here are two that have been recommended in the past on other MB boards.
www.sfxperformance.com/parts/VIB7101.htm
www.metalcat.com.au/
Old Aug 20, 2010 | 12:37 PM
telpsicorei's Avatar
1999 E 55 AMG
Okay yeah I've seen those before. now should i get 2.25" or 2.5"?
Old Aug 20, 2010 | 01:40 PM
1999 E 55 AMG
I found a cheap direct fit replacement. but I have never heard of this brand before
http://www.partstrain.com/store/deta...on=Driver_Side
Does any one have any experience with this??
Old Aug 22, 2010 | 03:19 AM
1999 E 55 AMG
2.25 or 2.5"? anyone?
Old Aug 22, 2010 | 04:18 AM
desired_speeds's Avatar
2007 SL55 AMG
I heard that stock piping diameter is 2.33?
Old Apr 18, 2012 | 04:26 PM
roguewrester's Avatar
1999 E55 AMG
I have a 99 E55 AMG and today I was pulling out of a parkinglot with the traction control turned off and as I gunned it to get out of the parking lot (not very hard though) it took off and before it went into the next gear I let off the gas and the car made a sound like a jack brake on a truck (like a loud rush of air is all I can think of). Ran fine after but when I got to where I was going and I was sitting at idle I heard a knock in the engine....... Did I just kill my car??? The knock isn't too bad and I don't know if its a rod knock or something else.. you can only hear it at idle and as the rpm's are coming down after revving.... Sorry, didn;t mean to hijack your thread.. Anyone ever have this problem or maybe have an idea as to what happened?
Old Apr 18, 2012 | 08:53 PM
  #32
2007 SL55 AMG
post a video of the sound if you can
Old Apr 19, 2012 | 02:57 PM
  #33
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Get the 2.5" pipes with the x-pipe in place of the 2nd cat. Also, get a pair of mandrel bands pipes in place of the resonator and your car will love you for that!! As far as high flow cats, i have not replace mine but if you google the net, you should find a few that would fit in that space.
OEM pipes are 2.33" hence will mate nicely with the 2.5".
Old Apr 19, 2012 | 04:14 PM
  #34
Schweinhund's Avatar
W210 E55
There are so many things wrong with these last three posts I don't know where do begin.
Old Apr 20, 2012 | 12:56 PM
  #35
Drewloera's Avatar
2000 w210 E55
Possibly
It sounds like a problem that I recently came across..Have your shop check the EGR valve. That can cause a lot of similar symptoms. I remember being at a red light, thinking that a earthquake hit when mine got stuck open.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
