Clunking sound under accel/decel
Old Aug 21, 2010 | 05:44 PM
John H's Avatar
14 E550, 07 E550, 69 Mach I, 65 Hipo, 66 Fairlane GTA Conv, 66 Fairlane GT
I'm getting a pretty good clunk from the rear end or rear suspension under both hard acceleration and abruptly letting off the gas. Most likely it is one of the rubber joints failing in the rear suspension. It doesn't feel/act like a bad u-joint.
Before I jack up the car, put on my grubbies, and just start poking around, I thought I would defer to the wisdom and experience here first as I have in the past.
Thanks!
Old Aug 24, 2010 | 06:05 PM
mufc's Avatar
2006 CLS55
Hi John
I think you might be on the right track with the rubber bushings in the rear suspension. What about the rubber donuts on each end of the drive shaft. Not sure if these could make that kind of noise?. Could also be a motor or trans mount if they are worn bad enough. I see some of the spare parts sellers list new mounts for the rear subrame also, I guess they sell them for a reason.
I for one would be interested to know what you found the problem to be.
Old Aug 24, 2010 | 07:25 PM
John H's Avatar
Thanks for the reply. I was thinking it may be an engine/trans mount too. I might just change those out first as they are on my 'to do' list and were one of the best things I ever did on my 300E.
Well, rather than jack 'er up and poke around I did what any MBWorld member would do. I posted here and then went out and washed my ride. Actually, I didn't have that much time and I had a pinched nerve in my back from carrying my napping 3 yo around at the local car show the week before.
The backs getting better so I will be checking it out this weekend and will let you know what I find.
Old Aug 29, 2010 | 11:37 AM
John H's Avatar
It's the motor mount.
I did the "one foot on the brake and one on the gas" test at idle and the motor jumped up a couple of inches.
This was an easy replacement job on my 300E. Anyone have input about this job on the 55? Part brand? I plan on doing the tranny mount too.
Old Aug 29, 2010 | 12:18 PM
saintz's Avatar
GL450
Tranny mount is very easy with a lift, but it's in the middle of the car, so hard to do unless you jack the whole car up.
Engine mounts you can find a DIY on here.
I took the parts to an independent and paid maybe $200 total for install. If you DIY, stay safe. If a jack goes out you can drop the block on your hand.
Old Sep 8, 2010 | 12:35 AM
John H's Avatar
Well, the driver side mount was completely seperated into two pieces. The pass side was sacked out as well. Much smoother at idle in gear. I've been babying the car for two weeks - now I can play again!
Old Sep 8, 2010 | 08:23 PM
mufc's Avatar
2006 CLS55
Glad you found the problem. Did you change the mounts yourself or have someone do it for you ?
Old Sep 11, 2010 | 03:34 AM
John H's Avatar
Did the job myself.
I started with the driver's side which turned out to be the harder of the two due to the steering box. A no-offset 16mm wrench is a must for the top bolt. It took about 45 minutes start to finish inuding the learning curve having never done this on the 55. Tranny mount took all of five minutes thanks to the geninus at MB who had the forethought that one day the mount would be replaced.
Almost hard to tell the engine is running at idle now.
Old Sep 13, 2010 | 07:46 PM
island55's Avatar
2000 E55
Where is the best place to get quality mounts?
