Two fans; one spins; the other does not.
Old Oct 27, 2010 | 05:54 PM
ruBENZ's Avatar
2000 E55 AMG
The two electric fans in front of the radiator work in unison (I assume) through the use of a belt. There is no belt. I took a shot in the dark and ordered, and received, an auxiliary fan belt. It appears to be the correct belt. Unfortunately, what I thought would be a simple procedure, is not. How is this belt applied? Can someone please throw me a bone here?
Old Oct 29, 2010 | 01:48 AM
Esh's Avatar
Esh
E55
I need to replace mine too.... SOMEONE?
Old Oct 29, 2010 | 09:21 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I replaced one of the fans a few years ago. I don't recall it as a difficult DIY. You should be able to change the fan on your own.
Old Oct 29, 2010 | 08:56 PM
Fabio D's Avatar
210 55
Wiush, i want to help you bro! but i never change this belt :S i see it, but never need to change anyone
Fabio Daniel
Old Oct 29, 2010 | 11:36 PM
ruBENZ's Avatar
2000 E55 AMG
Fabio Daniel
Thanks anyway. Looks like a simple application. It's just about finding the appropriate route to it. I may have to just start tearing away at the front end.
Old Oct 30, 2010 | 03:53 AM
2002e55amg's Avatar
2002 E55 AMG
I thought that one fan spins for the heat/aircon for the car and the other one is for like intake fan?
Old Oct 30, 2010 | 12:29 PM
ruBENZ's Avatar
2000 E55 AMG
My mechanic says it needs a belt that is missing. He wants $75 parts/labor. I ordered the part for less than $6.00. I just need to find the route to install it.
Old Oct 30, 2010 | 10:39 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The belt will still be there, they eventually harden and fall off. Its a simple but fiddly job. Start by taking the top radiator supprt off, undo the fans and push the condesor backwards a bit untilo you can get your hand inbettween the fan and the condensor. Put the belt o 1 pulley and roll it onto the 2nd pulley. Not a hard job, just takes a little time. Remember to take the old belt out (it will have fallen to the bottom).
Old Oct 31, 2010 | 12:17 AM
ruBENZ's Avatar
2000 E55 AMG
At last, a way. Much appreciated.
Old Oct 31, 2010 | 05:15 PM
Fabio D's Avatar
210 55
maybe it helps:
http://www.peachparts.com/Wikka/W210MiniFanBelt
Fabio Daniel
Old Oct 31, 2010 | 05:41 PM
desired_speeds's Avatar
2007 SL55 AMG
I do remember both fans spinning if you spun one of them. I'm glad you found that your problem was just a $6 belt.
Old Nov 1, 2010 | 11:49 PM
ruBENZ's Avatar
2000 E55 AMG
Hell ya. Thank you very much.
Old Nov 6, 2010 | 07:31 PM
2007 SL55 AMG
I just realized my car's aux fan belt is broken too. Where did you order your belt from?
Old Nov 8, 2010 | 01:15 AM
ruBENZ's Avatar
2000 E55 AMG
www.germanimportedparts.com
part# 011-997-0092
Make sure it fits your 02; mine is an 00.
Old Nov 9, 2010 | 12:53 AM
2007 SL55 AMG
thanks for the help!
Old Nov 10, 2010 | 03:47 PM
ruBENZ's Avatar
2000 E55 AMG
Finally got around to replacing my auxiliary fan belt. A fairly simple DIY which required a phillips screwdriver, a 10mm socket, and a 13mm socket to remove the horn. Replacing the fan belt assembly was the only PITA. Just dropping it straight in was the best method. Nonetheless, a PITA. BTW, I found the old stretched out belt at the bottom of the radiator. And, I removed all the debris in front of the radiator while I was there. Many thanks for all your replies. And, my hat off to Fabio D for an excellent pictorial link.
Old Nov 11, 2010 | 08:55 PM
Fabio D's Avatar
210 55
many thanks bro happy feeling helping other friends!
Fabio Daniel
