Engine mounts
Old Mar 29, 2011 | 10:12 PM
Fabio D's Avatar
210 55
Originally Posted by jtbeche
Update: Tons more power. It's unreal how much more the tires just smoke off when I jump on the gas. I didn't figure this to be a side benefit, but I'm pleasantly surprised by it.
More power? you kidding! hahahahaha you disconnect the battery when you replace the mounts? i'm sure the extra power you feel its maybe the erased adaptation in the ECU/TCU units! please confirm
Fabio Daniel
Old Mar 30, 2011 | 09:49 AM
jtbeche's Avatar
02 E55; 99 CLK430 (Sold)
Nope....didn't disconnect the battery. Personally, I didn't see the point. Shrug.
I've tried the key, gas pedal reset thing and I've never really felt a difference with that.
Old Mar 30, 2011 | 11:14 PM
Fabio D's Avatar
210 55
wiw! hard to tell now :S i agree with you, didn't figure this to be a side benefit! but good for you & glad you have the car running great now!
Fabio Daniel
Old Mar 30, 2011 | 11:33 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
The engine is correctly held in it's proper place with the new mounts. (At least the driver's side.) The torque is now correctly distributed and not lost in incorrect geometry.
Did you get both tires to smoke?
Old Apr 19, 2011 | 06:09 PM
lseguy's Avatar
2005 c230
Great info, but can someone post specifically how they broke loose the drivers side mount? Exactly what tool did you use? Was a breaker bar needed? I can only get a stubby up in there, and with the stubby, I have no leverage to break the bolt free.
Old Apr 19, 2011 | 09:10 PM
mfletch69's Avatar
1999 E55
I am going to do this. What about the tranny mount? Does it neccessarily NEED to be replaced at the same time?
Old Apr 19, 2011 | 09:55 PM
  #32
cudaized's Avatar
No. But why not do it. The tranny mount is relatively inexpensive.
When I did mine, I did all three. Easy job.
Old Apr 19, 2011 | 10:16 PM
  #33
ESTJ's Avatar
2001 E55 AMG - 2001 E320 - 1990 300CE
You are so right my friend, this bolt is a bear. I used two humans, one six point socket, a 3/8th breaker bar and a large lever like a 1 1/4" wrench. First position the socket/breaker bar on the bolt such that the breaker bar is close to the engine block, then use the lever between the engine block and the breaker bar to break the bolt free. You will probably need two people, one to make sure the socket stays on the bolt while the other moves the lever. Just the slightest movement will set you free. Use blue locktite when reinstalling the bolt.
Good luck!
Old Apr 20, 2011 | 07:52 AM
  #34
lseguy's Avatar
2005 c230
thank you very much for that info.
Old Apr 20, 2011 | 03:49 PM
  #35
lseguy's Avatar
2005 c230
Finally..some success. I used about a 6 or 7 inch 3/4 breaker bar and shallow 6mm socket. (I first tried a stubby ratcheting box wrench from Harbor Freight but it never seemed to sit down far enough on the bolt unless I kept a hand on top of it pressing down, so I abandoned that method and went to the breaker bar/socket).
So with a 18 inch breaker bar from harbor freight pushed up against the engine block in that area of the exhaust manifold I was able to then use the breaker bar as a lever and pry back against the breaker bar going towards the drivers side fender.
Old Jun 4, 2011 | 03:17 PM
  #36
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
i just got my engine mounts done today and it feels like a new car. i can't even feel it running at idle now (in P or in gear). one of them was leaking and the other one was in pretty bad shape. i took the car to my friend's shop and he had it done in less than 30 minutes. i got the mounts from autohausaz.com and will be using them again when i need parts.
old mounts
