Multi Contour Seat Cushion replacement - OEM or aftermarket foam?
Old Jan 29, 2011 | 11:12 AM
Schweinhund's Avatar
W210 E55
So my drivers side is like sitting in a hole. I have an auto upholstery guy who will put common seat foam in it. To me these Mercedes OEM seats are not all that comfortable. My guess is foam would be much better but am not sure. Anyone had this done? Cost would be about the same for the OEM rubberized cushion vs the foam.
Old Jan 30, 2011 | 09:13 PM
W210 E55
Nobody eh? I'm going OEM. Who knows what the foam will do to other items in there.
Old Jan 30, 2011 | 10:58 PM
Fabio D's Avatar
210 55
Go for OEM if you want a perfect finish bro!. my guess
Fabio Daniel
Old Jan 31, 2011 | 01:28 PM
W210 E55
Thanks . When in doubt, go OEM.
Old Jan 31, 2011 | 02:39 PM
desired_speeds's Avatar
2007 SL55 AMG
can you take pics and document the cushion change because I'd like to do the same in the future. My cushion is starting to feel a bit soft. thanks!
Old Feb 1, 2011 | 09:37 AM
W210 E55
Sure will.
Old Feb 10, 2011 | 01:42 AM
W210 E55
Just got the cushion in from the dealer. Had to special order from Germany. Got it for $100. Great deal IMHO. It even came with a new front air bladder as part of the assembly. That saved me $30 extra bucks as mine leaks.
I'll try to put it in this weekend. I'll take photos. I am thinking it is not a bad job at all.
Old Feb 10, 2011 | 02:44 AM
2007 SL55 AMG
can't wait for the pics! so the seat cushion bottom only has 1 air bladder?
Old Feb 10, 2011 | 02:53 PM
W210 E55
yes. It's the "seat length adjuster". The three others are on the backrest.
Old Feb 10, 2011 | 11:31 PM
2007 SL55 AMG
ahh! that explains it! I always thought there were bladders where your butt goes and that mine were bad. But my cushion is also sagging a bit and I'd like to fix it.
Old Feb 11, 2011 | 02:41 AM
W210 E55
Well got home and became a bad dad and disconnected husband and decided to do the cushion. Let me say it's not the easiest job. The documents I reviewed prior were pretty useless. If one is mechanically inclined and has no trouble with connectors, hoses, and bolts all over the place and upholstery clips and can work carefully, then this job is not impossible but on my scale, it is a hard job and I do all kinds of work on cars. Took me 5 hours working at a good clip. I took lots of pics and will try to post them along with a "how to" this weekend. Seat feels nice and new now but would probably advise replacing the spring as well if going in. It looks to me like the spring in these seats could wear out but so far, so good. Also replaced the "stepped" bolts with factory upgrades to eliminate the "popping" noise from the seat rocking on acceleration/braking. That's the time to do it.
I will say this, that if I have to go back in, the job would take a lot less time as I now know the proper order of things and what to do on each step. I'll write it up so hopefully someone else won't have to explore as much as I did.
Old Aug 22, 2011 | 01:17 PM
billbillw's Avatar
2001 E55 AMG (sold)
Any chance of getting that DIY write up?
Old Aug 22, 2011 | 02:14 PM
W210 E55
Sure. I misplaced the pics and can hopefully find them.
Old Aug 22, 2011 | 02:18 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
damn man , thats krazy I wouldnt know where to begin .. I get the popping sound to somtimes on acceleration .
Thought just cuz ima big guy it did that but I guess it happens to others also
Old Aug 22, 2011 | 04:20 PM
W210 E55
The bolt is pretty easy. Getting the seat out is easy except for the air lines in front, but nothing difficult.
