Conservative estimate of HP gain from headers, exhaust, tune?
I am exploring some reasonable upgrade options. From what I have read, the exhaust is the place on these W210 cars where there is horsepower to be gained. The induction is plenty good.
My idea is:
1. headers
2. single high flow cat on each side
3. resonator removed
4. 2-1/2" exhaust from headers out
5. retain stock muffler
6. ECU tune
What can I reasonably expect at the crank or wheels?
My idea is:
1. headers
6. ECU tune
1 Post
2001: Supercharged E55 AMG
Hi!
Those are the best mods for a W210 E55 if you want to maintain the reliability. I drove my car like all N/A that before i installed the S/C. It had aprox 400-420 HP and 600 NM on the crank. Trapped 179 Km/h (111,5 mph) on a Racelogic Performance Box on a normal summer day here in Sweden.
I have a few videos on my youtube account when my car was in this mode.
http://www.youtube.com/ljungwald
x-pipe
My idea is:
1. headers
6. ECU tune
My idea is:
1. headers
6. ECU tune
Don't mean to rain on the parade but I wouldn't bother.
I have an 01 E55 with shorty style headers, X-pipe with secondary cat deletes, underdrive pulleys, 211 style airboxes and a tune. The car made 317 whp on a dynojet dyno. Approximately 15 whp for $4,000 is not worth it.
I would save the money and put toward a W211.
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
2011 GL550, 2004 Audi S4 v8
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
It sounds 1000 times better and the gains are outstanding...sounds like the only bubble bursted was yours
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
![](http://i856.photobucket.com/albums/ab122/gandalfthegray_1/E55-1.png)
I agree on the sound being improved. The car does have a nicer deeper tone.
I do not agree on the 'is it worth it'. $3312 for 15 - 17 whp is absolutely not worth it. Other than the sound the cars drives much the same as before, and why wouldn't it? Do you think 15 whp in a 3600 lb car is going to make any significant difference? No.
Basically this is how I see it. The W210 AMG E55 is a great car in it's stock form and the boys at Affalterbach didn't leave much on the table in the way of lost horsepower. There is little to be gained without forced induction and they knew and that is why the W211 is as such.
If you folks feel that the gains are money well spent then that's fine as well, but I wanted to let the OP know that the price per horsepower is outrageous imho.
As stated these numbers still don't really add up. Should be higher. In order to get a accurate dyno number the esp has to be completely turn off or numbers will not be 100% accurate.
Inaccurate reading
https://mbworld.org/forums/w210-amg/...eally-off.html
How else can you turn off traction control? When I launch the car this way there is no traction control activating either, it will spin til the tire blows if I stayed on it. I'm sorry guys but I think it is/was off.
On the w210 AMG it traction control is never fully off unless deactivated from the unit itself. If you noticed when you had the car Dyno'd the esp light would flash.
I see...this explains why you thought 15hp cost over $3K. There's no way they gain only 15hp with these mods.
I'm just as guilty about knowing about the ESP though..learned something new
no esp
I think for all that money done to the car, you should spend maybe a few more bucks to have someone...some how rig a switch to the dash where you can have the esp turn on or off.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
1999 E55
I agree that the AMG bunch did not leave much on the table....however, I have a stock 2000 E55 & and 1999 with AMS headers, x/pipe/res delete & secondary race cats installed and I can tell you that the modified E55 drives very differently than the non modified. The torque delivery is increased and the max occurs noticably earlier in the power band & the shifting pattern is different because of that. Side by side, the car walks away from the stock E55 - especially from a 30mph rolling start, when the ESP is not such a leveling factor
Headers $1500 installed
other stuff - $500
Tot = $2000 for engine performance
Due to the increased torque and after a recent trip to the smokey moutains, in the revised beast, I realize the center of gravity simply HAS to be lower. I am overpaying a couple hundred for Euro Springs vs Eibachs because I want the OEM parts and I want to retain the stock shocks and intended Euro designed ride and stance. Suspension total will end up being around $800 installed.
So $2800 total to unleash the beast and keep the rubber on the pavement. To me, that is not much to spend to "un-USA" spec the car and put it the way the AMG engineers envisioned...which I why I own these cars in the 1st place.
IMHO, the tune (the ECU's on these cars are self adapting) and pulley are not in the scope of AMG design (if the AMG engineers wanted a light pully, it would have come from the factory with one) and are the waste of money...& those were $1800 of his $3000 bill. That money would be better spent on a modern stereo, suede headliner and routine maintenance.
other stuff - $500
Why you guys, change the intake airbox by the W211 design? i'm pretty sure the W210 amg box has better design for N/A cars.. Someone have dyno chart before & after to this mod? I meen, w211 amg comes with this air boxes cause not have anymore room for biggest ones, w210 amg air box has a perfect design to our cars.. I only modify my inntake by a renntech carbon one, cause they are bigest :S how do you think guys?
Fabio Daniel
Fabio Daniel
1 Post
'88 560SEC, '94 E320 Cab, '95 SL320 AMG, '96 SL500 AMG
Are the headers of the w210 E55 very hard to remove and install? Brought the car to a new shop today and the mechanic was saying labour might cost a lot as its a tough job. Not sure if he is trying to scam me / just doesn't know his crap.
They aren't too bad but it will take some time. I had a friend helping me and we worked from both the top side and bottom side to get at some of the bolts. I figure we probably spent 3 - 4 hours. Had a few knuckle buster moments but it certainly is doable. It is labor intensive, more so than the plugs though. I'm guessing the shop is talking $400-$500 or so?
1 Post
Its pretty easy to pull 50HP out of these W210 E55s.
If you only got 15HP, then you did not dyno the car properly. You have to physically go into the engine and unplug the massive ESP/ABS plug on the drivers side. If you did not do this, your dyno results mean nothing.
I can assure you ... it is quite easy to pull out stupid power out of these engines if you know what to do and in what order. 400-420 is very achievable without getting into the motor itself and can be done for less than $3k easy.
Well I can tell you nobody would be more happy to find the missing hp than myself. I will make a trip back to the dyno and this time I will disconnect the system entirely. I will post back the results for anyone interested. This probably won't happen til June however.
So this brings up the my next question; when I run at a drag strip am I to unplug the system as well to get my HP?
esp
Last edited by snooozie; 05-09-2011 at 10:49 AM. Reason: forgot to add a few things
