Removing Side Skirts W210 E55
1998 W210 E55 AMG
Can anybody give me a clue as to how the side skirts are removed from an E55 (W210) - I've only had it up on jack and I know there are half a dozen or so bolts on the underside of eack skirt (8 & 10mm),,,,,,,,,,,but are they fixed elsewhere too, as they seem reluctant to move with the bolts removed from the underside.
I don't want to force obviously, as don't want to damage. Need to repair a small crack hence the reason for the removal in the first place.
I'm assuming its simple - but so am I?!
Mark.
Mark.
2001 E55 - 2008 CLS63 -2016 F-150
Forum search and google are your best friends when looking for these types of things .. honestly if i had the time to google it so should anyone else .. but here i saved you the trouble .. Nice intro post BTW ..
https://mbworld.org/forums/w210-amg/...er-panels.html
No special tool needed. you need to peel off the black stripe in the superior part of the skirt (open 2 doors & you will see a black stripe sticker) remove it, remove 5 or 6 screws, remove the lower screws & they pop of very easy (you need to pull it to front a little to desengage it to the fender clip)
you can thank Fabio D for that info !!!!!
1998 W210 E55 AMG
Thanks for that (and Fabio D) for the info.
It was the black strip that threw me - I wasn't sure whether if I peeled it back I'd damage it.............but had wondered if there were additional screws under there!
I appreciate your help.
Cheers
Mark.
Cheers
Mark.
1998 W210 E55 AMG
Hey mate! i re-use this stripes in my car and works perfect i want to replace it cause a previouse skirt paint put some "blue paint fogger" in the driver's side stripe and i dont like it, a friend quote me the stripes at 16$ each. not major.. But if yours are fine you would re-use it
Fabio Daniel
Fabio Daniel
1998 W210 E55 AMG
E55 Skirts
Fabio Daniel
Fabio Daniel
Thanks Fabio, will try and re-use. But do you have part numbers for the stripe if I have a problem?
Mark.
You can always bring the stripe to the mb parts dept and they will match it with the parts # on their parts site and order them for you. No worries...hope that helps.
1998 W210 E55 AMG
E55 Skirts
On three occassions they've had my VIN number and managed to order wrong parts for me..................so I like to educate them.
Maybe your dealers there are better then over here!
Mark.
