will 9 inch front rim be too wide ?
2001 E55 - 2008 CLS63 -2016 F-150
E55, GLS450, GL63, GLE350
I suspect the correct offset would be in the 25-26mm range. But, that is half of the issue. At 9" , the optimum section width would be 275. And, there is where your problem begins. In the past, I have run 8.5, ET35, 245. And, that was dang close to the infamous suspension bolt. Even at ET25, a 275 or a 265 would probably rub. Leaving you with the option of 255 or 245 which would look ridiculous on a 9" rim. Bottom line: move on.
I dont understand how he running a 9.5 inch rim on the front . What kind of tires you got on there ..
So if i understand Rubenz, your saying a 275 tire should be lowest on a 9 inch wide wheel .. My tire guy told me to run a 235/35 on a 20x9 front wheel ?
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
a 235 is small for a 9" wheel. i'm running 235's on my 19x8.5" front wheels and it looks kind of goofy with the sidewalls being stretched IMO.
thanks ruben
my wheels will be here tomorrow hopefully then can test fit first .
After speakin to couple wheel/tire sponsers via pm they said i should be fine with 235/35 20 on 20x9 inch wheel .. guess ill see how bad it is .. they recommended 275/25 for 10inch rear but i cannot find a tired for life of me other then $400/ tire only 3 makes or so
if he can rock these on 20's and not have any issues .. I gotta be good with 275's on the back
http://m.www.mbworld.org/forums/showthread.php?t=289309
Tire size
9.5 up front? Are you Lowered any? I'm looking at a 9.5 up front also at 40 offset which I will need a spacer but want to run 255/35/19 or 265/35/19. Thanks
