rear subframe mount leak
Old Dec 20, 2011 | 01:50 PM
vincentie's Avatar
2000 E55
My left side rear subframe mount is leaking!!! Is there any easier way of changing it without dropping the whole subframe?
Old Dec 20, 2011 | 02:10 PM
Drewloera's Avatar
2000 w210 E55
Post. Pics
Old Dec 20, 2011 | 06:26 PM
vincentie's Avatar
2000 E55
Will do , but it the one closest to the wheel and toward the front right near the dog leg!!!!!
Old Dec 22, 2011 | 11:47 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Those mounts are not liquid filled. Maybe it got wet and look like they are leaking oil.
Old Dec 22, 2011 | 01:20 PM
vincentie's Avatar
2000 E55
Man,that's what I thought but its leaking everyday and I don't see anything else near there except a brake line but oil is coming above that!!!! When I get a chance ill post a pic!!!!!
Old Dec 22, 2011 | 03:31 PM
Fabio D's Avatar
210 55
The front mounts yes. This mounts have phenolic oil inside. the rear's not. You need a new subframe mounts. (Common fail in the W210 chassis) You would replace only the front ones, but i recommend you to change all 4
You not got some strange noise in the rear suspension with road bumps? when this mounts fail and expulse the phenolic oil start to making noise in road bumps
Fabio Daniel
Old Dec 22, 2011 | 08:19 PM
vincentie's Avatar
2000 E55
Nope, no noise. So do have to drop the subframe to do this job or can one of those on car presses work??
Old Dec 23, 2011 | 08:06 AM
Fabio D's Avatar
210 55
No you dont. you only need to remove the screews in a bridge and lower the subframe by a 4 inchs, but you need a special tools (oem mercedes workshop tool) to remove the old ones and press the new ones on to the subframe again. (you canot do that by your self) is a little hard to replace that, i recommend you a stealer or go for an specializaed indy shop we replace lots of that here and you need to broke some metal parts in the old mount to remove it. is not easy.. But YES, the phenolic oil comes by the mount!
Fabio Daniel
