6000K LED H3 Fogs
- Decent quality
- No resistor apparently so "light failure" comes up (I am inquiring about this with the vendor)
- Not nearly as bright as the standard bulbs but still light the fogs up enough to looks really good. IMHO, the standard fogs didn't do much anyway.
- Matching is very good with 6000K Xenon D2Rs and 5000K City Lights
- BUT now the city light 5000Ks look off (close but still off)
- Installation note: these are long and inside the fog housing is a forward metal light shield plate. You need to stick your finger in there and bend it back a bit. Since I knew the LEDs were not going to be that bright, I bent it all the way down, as far as it could go so that all of the LED would be used (ie none of it blocked).
Im curious as to since there is CREE LED they dont use those instead of SMD .. maybe burn to hot if left on too long but it works in flashlights cant see why not in foglight housings and the light it would throw would be krazy
I suppose when I lock the car, and the fogs come on, the seem just about as bright as my old bulbs. Not quite but they light up nicely.
As for the resistor, I am looking into it. Even if the don't have one, I will find the right one to add in. Doesn't look too hard.
for me biggest pain was jackin it up everytime only to leave them till next set came in and jack up again to change out .
The only way these type of bulbs will have Throw is if each led is like 5-6 each then you talkin EagleTec Throw lol
edit: just googled something for hell of it wonder what type output these suckers would have lol
http://www.aliexpress.com/product-fm...olesalers.html
if this guy was USA id deff grip these to try out
I am now looking into an HID H3 setup. In which case the fogs would become very bright and I could match the 6000K xenon headlights exactly.
I am now looking into an HID H3 setup. In which case the fogs would become very bright and I could match the 6000K xenon headlights exactly.[/quote]
Just a little heads up .. See if you can find a reputed seller that sells with no error warning setups I think there is a forum sponsers that sells them .. It really is hit or miss because some have had the best luck while others seem to get some DOA or something blows out . Ive come to the conclusion if the name on the HID ballast says XENTEC either the ballast or bulbs will not last too long . I purchased 55W kit this time around for a little more then what the 35W kits cost but since last year I havnt had an issue with any bulbs or ballast burning out and with the 3-4 35W kits always seems to have something come up ..
Also when installing the HiD bulbs .. the seating of the HID bulb will be a little bit off also because the regualar H3 seats all smooth n fliush because it is thin metal backing compared to plastic on the HID . And the wires coming out the back of the HID bulb will interfere with the CAP that goes back on . Ive seen ppl drill a 1inch diamer whole and seal with a rubber plug , Me I splices the wires ran them through the vent on the cap and installed that way maybe have been a little harder to close to cap but it works and fits and no issues almost a year now so just letting you know if you are goin that route
Also when installing the HiD bulbs .. the seating of the HID bulb will be a little bit off also because the regualar H3 seats all smooth n fliush because it is thin metal backing compared to plastic on the HID . And the wires coming out the back of the HID bulb will interfere with the CAP that goes back on . Ive seen ppl drill a 1inch diamer whole and seal with a rubber plug , Me I splices the wires ran them through the vent on the cap and installed that way maybe have been a little harder to close to cap but it works and fits and no issues almost a year now so just letting you know if you are goin that route[/quote
Thanks for the heads up! Wise advice.
btw, I've never had error codes using any HID kits on the w210.
As for install, I drilled the hole and shoved the grommet in between. Very clean install if you were to ever see it.
