Best method for alternator removal?
I am having some difficulty in determining the best course for removal. WIS says to remove lower cover and drop the alternator our of the bottom. From my research on the forums, others say you have to undo the engine mount and lift the engine for removal. AllData says the radiator has to be removed.
Can anyone offer insight into the best way to fully remove the alternator once it is loose?
http://www.benzworld.org/forums/w210...ml#post3515472
