DIY: Spark plugs and wires (pix)
Old Oct 31, 2007 | 03:35 AM
Eurosport's Avatar
monowiper
so since it's been awhile since i've actually written a DIY, might as well do a quick one
first things first, removed airbox (pops up) and the tubes to make some room
no airbox in the way=more room
next i'll have to remove the coils to create even more room, but first i'll take some pix for referance just in case i need to see where the wires go back
pretty simple, short wire low, long wire high
using open ended wrench to "easily" remove the baked wire, propping against the valve cover
yes, i told you it's baked
FTMFW? hmmm no
Yeeeeeeeeeees! one coil out 7 to go lol
oh yes coil is held on by one torx T27 nut, almost forgot to mention
this is a good time to clean around areas where no MB tech will, they just don't give a foook about your dust/dirt, just a rumor ;p
prepared my spark plug socket, that extention was a little long for the drivers side so used a smaller one...
good thing to use a little electrical tape on the socket that way you can never drop it, easier to play with it while you remove the spark plugs
flex your muscles
first one is out
hmmm hold on a sec, I thought it's supposed to be 100k right? riiiiiiiiiiiiiiiiiiiiiiiight
junk, trash, garbage
(only 49k on them btw)
wires baked on them, gap pretty big (i don't have a measure device but it does look too big by my eyes), etc. etc.
clean around some more
there you have it, pretty much a breeze just make sure you're careful with your hands around the heat shield on both sides, very sharp ;p
it's not that bad really, i think my X5 was more of a pain this weekend due to less space to work with on the drivers side
so now you may wonder why no pix of installing it back, lol
well my parts are not here yet, waiting on Magnecor wires and new spark plugs to be shipped
Eurosport
Old Oct 31, 2007 | 10:08 AM
JamE55's Avatar
Out Of Control!
Old Oct 31, 2007 | 10:15 AM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
great DIY.
Did you replace the ignition coils/wires?
I'm not techie, but MB wanted tons of money for the parts plus several hours of labor to replace both wires and plugs.
Also, they wanted $20/spark plug at MB.
Old Oct 31, 2007 | 12:02 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Well Jamesparkowire, here you go and I was just about to take pics of this same job but thanks Eurosport, now I don't have too, lol...
Btw, my Magnecor wires just arrived drop-shipped directly from Magnecor, how great is that!!!
Old Oct 31, 2007 | 12:35 PM
JamE55's Avatar
Out Of Control!
Already saw it Jumbledore!
Old Nov 1, 2007 | 09:17 PM
SleepersRock's Avatar
2008 W211 E63
Superb..Thanks Eurosport!
Old Nov 2, 2007 | 12:43 AM
suicidal4life's Avatar
2001 E430
Eurosport
I'd be worried about something getting into the cylinders while the plugs are out for an extended period of time but other then that the job looks pretty straight forward and easy.
Old Nov 2, 2007 | 01:05 AM
ProV1's Avatar
MB, BMW
sweet write up.. i need to do this.. can someone come over & do it with me??
how much do the OEM wires cost online..?
Old Nov 2, 2007 | 11:47 AM
Drive out to LA and we can all do it together...
Old Nov 3, 2007 | 09:22 AM
NitrogenBalance's Avatar
none
I remember this job, looks about the same amount of clearance. Maybe a tiny bit more room than the 202. It took me a while that day. @ 60K when I changed mine they were in the same condition as yours.
I've had the magnacore wires with NGKs for over a year now and they are great. No issues. I due wish that I bought some heat sheild wire sleaves for added protection before I put everything together. Its very hot and close in there. Looks good.
...I thought the 210 55 used the green injectors like the 43 but I see yellow?
Old Nov 3, 2007 | 10:00 AM
Karlson's Avatar
06 E55
do you know whats the their flow rate? Bosch greens once flow 450CC, and I thought yellow got a less a flow. but I am not sure, thats why I ask
Old Nov 8, 2007 | 02:55 PM
Eurosport's Avatar
monowiper
ok, my wires finally arrived yesterday, installed them (i had new spark plugs already in, bosch platinum single electrode...)
all i can say is damn lol car feels good,
before the plugs change there was a little engine vibration you could see it at idle (and no my motor mounts are perfect ;p)
that is gone, at idle is just very smooth right now
took it for a spin, felt very very good, very responsive, also outside temp might have helped (45F)
i could definitely feel it was pulling a lot stronger though specially between 4k-5k
i don't know how much the wires helped since i did wires/sparks at the same time, i can't comment on them besides, the quality of them is great
and to Ohlord lol and his 100k intervals on plugs, i say bs
that's all
Old Nov 26, 2007 | 06:08 PM
43fatman's Avatar
2001 E430 Sport
I did my plugs this past weekend. Thanks for posting the pictures, the 55 motor looks the same as mine when you pull your air box off. When i pulled one plug out for inspection i noticed the plug wire to be in great shape so i chose not to get new ones. I think the plugs had been done once before i got the car i now has 120k miles on it. The 17mm wrench worked great one thing i would like to add is on the rear drivers side bank i could not access the metal part at the end of the pulg with the 17mm wrench so i put a zip tie around the metal part and pulled on it from there ( i guess you could pull on the wire if replacing them). Thanks for the post!
Matthew
Old Aug 3, 2008 | 04:00 PM
cambodianricer's Avatar
E320 W210
so where would you guys recommend ordering the spark plugs and/or wires ?
I need it for a '00 E320 which has 91K miles
Old Aug 3, 2008 | 09:18 PM
Tacjam's Avatar
2000 W210 E55// 2007 Toyota Tacoma X-Runner
You can
get the wires here for a great price.
http://www.alamomotorsports.com/Magn..._mercedes.html
I would recommend these Bosch Spark Plugs...they're the direct replacement for Bosch F8DPER which your owners manual recommends....AND 16 plugs will run you around $85 shipped.
http://store.impartsol.com/sparkplugbosch23.html
Just noticed this is for an E320....less money for you!
Jim
Old Aug 5, 2008 | 10:14 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
thanks Eurosport. Do you always work under the hood with a nice watch on?
Old Aug 5, 2008 | 05:46 PM
Ben'z's Avatar
E320
+1
Old Jan 20, 2010 | 11:16 PM
06E55's Avatar
2006 E55, 2012 Bentley Continental Supersports Convertible, 2014 Kia Sorento SXL AWD
Is the process pretty much the same for the 06MY? Can anyone tell me the part numbers of the OEM plugs/wires?
Old Jan 21, 2010 | 12:03 AM
M-bENZ's Avatar
Corrolla
Jim
how come there is no spark plug for W209 chassis I looked everywhere but didnt see from that site.
Eurosport,
Where did you get your spark plug/wires ?
Andy
Old Jan 23, 2010 | 06:48 PM
CTE55AMG's Avatar
1991 300CE
I changed all 16 plugs today as well, pretty easy job despite all the hype. If you know how to change 1 plug, you know how to change 16 of them
Old Jan 25, 2010 | 07:21 PM
island55's Avatar
2000 E55
Might want to consider replacing the valve cover gaskets whille everything is already out. They WILL leak if they havent started already. Saves time having to remove everything all over again. Besides there like 20 bucks for both sides. Just my 2 cents.
Old Jan 25, 2010 | 08:39 PM
Fabio D's Avatar
210 55
Euro! what yr is ur car? i see you have the 1-5-4-2-6-3-7-8 firing order. is very extrain if you see the engine & review the firing order sequence in the pistons. the 2 final fires are 7 & 8 (same side) one back other. i can't understand why. my car is a 99 & the firing order is 1-5-8-4-6-3-7-2 is a little more ordered if you see the engine sequence, i understand they don't affect the engine performance, but i think the camshafts need to be different in the models with this firing order. is your car pre-updated or post-up..
my car has green fuel injectors i see your car has cream ones. i think your car is post updated right?
thanks in advance
Fabio Daniel
Old Feb 13, 2010 | 03:27 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Great DIY post, Eurosport. BTW, the dealer charges $25 a plug x 16 = $400 for our cars. Labor isn't as bad at $235 as quoted, but the whole deal is still $635+. I wonder if you could buy the plugs for $160 and then have the dealer install?
Also, I think the 100K miles intervals is a little too long myself. I had mine changed at 57K miles, and it feels a lot crisper.
Old Feb 20, 2010 | 01:30 AM
Eurosport's Avatar
monowiper
Eurosport,
Andy
i got wires from the Alamo link above
spark plugs i usually get them from http://www.autohausaz.com/
Old Feb 20, 2010 | 01:31 AM
Eurosport's Avatar
monowiper
yes they are all the same, same engine, even other MBs, all have same layout
