Master Cylinder replacement easy?
Also secure the painted areas so you don't get any brake fluid on it. It WILL remove paint. If you get some on there, wash it off with soap and water right away. Brake fluid absorbs water so that's the best to use to remove it.
The only one you cannot mix is DOT 5.
http://www.pentosin.net/specsheets/P...SuperDot_4.pdf
ZAYED,,
