Engine Bay Bling
Old Aug 23, 2013 | 08:21 PM
ddb's Avatar
ddb
2002 E55
Engine Bay Bling
Since I purchased my car at the end of April I've been bothered by the rough looking engine cover/air box. I've only wiped it down with a wet rag to get the dust and debris off of it, but it still looked crappy. It just looked grainier and more beat up than some others that I've seen in pictures.
So I thought I would see if I could make it look a bit nicer. I was inspired by the beautiful Renntech air box in carbon fiber. I actually want to purchase the Renntech air box, but will wait until I can find a decent deal on a used one after I get some other items checked on my E55 to-do list.
I didn't have much success getting a decent picture this evening. Shadows from the hood, my shadow, etc. prevented me from capturing a decent image. I will try again when the conditions are better.
ddb
Old Aug 23, 2013 | 10:30 PM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
looks good
Old Aug 23, 2013 | 10:46 PM
DOUBLE-LINCOLN's Avatar
w210 e55 amg
Wow it acually looks good.......hydro dip right? Thought maybe wrap at first. I wonder how long it will last from engine heat... Nice job
Old Aug 24, 2013 | 02:29 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Looks sick.
Once you get the Renntech setup I may be interested in what you currently have if it's held up.
Old Aug 24, 2013 | 08:38 AM
ddb's Avatar
ddb
2002 E55
Thanks, guys.
Yes, hydrographics. I'm going to have my b-pillars done and maybe some other parts down the road.
The engine cover/airbox has multiple coats of automotive grade clear on it. I hope it proves to be very durable. We shall find out.
Old Aug 24, 2013 | 09:33 AM
snooozie's Avatar
I always wanted to do this with my front grille. Can you sent me a link where I can get these stuff or is it on eBay?
Old Aug 24, 2013 | 09:56 AM
ddb's Avatar
ddb
2002 E55
snoozie,
It isn't a DIY type of deal although there are probably vendors on eBay offering their sevices as well as what's needed to do it DIY.
I had mine done here:
www.stricklandhydrographics.com
Interesting thought with the grill. I've thought about spraying mine black with the rubber coat stuff to see if I liked it. What are you planning with yours? All black?
Old Aug 24, 2013 | 10:04 AM
ddb's Avatar
ddb
2002 E55
More Pics With Better Light
URL=http://s143.photobucket.com/user/dbrown0529/media/E55/Carbon%20cover/1377350683567.jpg.html][/URL]
URL=http://s143.photobucket.com/user/dbrown0529/media/E55/Carbon%20cover/1377350684143.jpg.html][/URL]
Old Aug 24, 2013 | 10:05 AM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
How much did it cost to have done?
Old Aug 24, 2013 | 11:10 AM
snooozie's Avatar
I always want to do a carbon fiber style wrap for the grille but this guy on our forum that does the wrap told me because of the heat the wrap will peel off.
Old Aug 24, 2013 | 11:45 AM
ddb's Avatar
ddb
2002 E55
Two-fiddy. Of course prices in your area may vary.
Old Aug 24, 2013 | 11:49 AM
ddb's Avatar
ddb
2002 E55
Maybe hydro-applied graphics is the answer. It conforms to intricate shapes and is covered with clear. If my engine cover holds up I would think a grill would as well. Time will tell.
Old Aug 24, 2013 | 04:48 PM
WBE55's Avatar
2002 E55 AMG, 1999 E55 AMG , Audi allroad 2.7T sold ,08 Jeep SRT8 sold, 06 TBSS Sold
R U kidding me that looks Great !!!!
Old Aug 24, 2013 | 05:26 PM
w210 e55 amg
It's possible to DIY. ...but I highly doubt it would all come out even...this job def professional...nit one wave in design and. All pieces match up...
you. Clean up the gunk on engine before pic ? How did ur valve cover seals look when u took box off? Leaking? I have some leaking also. Supposedly my MB guy says it will mess with injectors then have bigger prob. ...I figure it's worth the 400$ to. Redo valve gaskets and top part new sealer
Old Aug 24, 2013 | 06:35 PM
ddb's Avatar
ddb
2002 E55
Thanks, WBE55!
DOUBLE-LINCOLN,
Thanks! Unfortunately I didn't do any cleaning, yet. Yep, I have a minor leak. The driver's side valve cover is dry. On the passenger side the main gasket is good, but that upper box on top of the valve cover towards the rear has a small leak. I believe I read there isn't a gasket, just needs to be cleaned and new RTV applied. Do you know if this is factual? If so I will attempt to fix it myself when the temperature drops some during the coming weeks. I can see how a bigger leak can make a mess and possibly screw up some stuff.
Old Aug 24, 2013 | 11:45 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
Easy to fix that small upper box. Just remove, clean, and reseal. I used standard black RTV. Of course, clean the surrounding areas.
Attached Thumbnails Engine Bay Bling-dsc00169-2-.jpg   Engine Bay Bling-08.jpg
Old Aug 25, 2013 | 08:15 AM
ddb's Avatar
ddb
2002 E55
Thanks, cudaized. I should have done it while the engine cover was out being dipped. I will get to it sooner rather than later.
Were both sides leaking on yours or just the passenger side? The driver's side on mine is dry.
Old Aug 25, 2013 | 09:30 AM
Vander's Avatar
Originally Posted by ddb
Thanks, WBE55!
DOUBLE-LINCOLN,
Yes there is No gasket for the upper breather. Use rtv silicone, but make sure you clean the old one really good first. I am currently doing both vc gaskets on my car and both upper breathers.
Old Aug 25, 2013 | 11:38 AM
ddb's Avatar
ddb
2002 E55
Vander,
Are your VC's leaking or are you doing a preventative replacement while you are fixing the upper breathers? How many miles on your car? I'm at 68k and mine look good at the minute.
Thanks,
ddb
Old Aug 25, 2013 | 01:53 PM
cudaized's Avatar
Valve cover gaskets are usually not the culprit. Most of the time just a slight tightening of the valve cover bolts will do it.
The gasket sealer from MB (original) on the PCV covers dries out. It shrinks and becomes brittle. Then brakes off in chunks. Allowing oil to get pushed out and dirty the outside of the valve cover. Easy to fix.
I did both sides at the same time. Including cleaning and sealing the oil filler neck/cap. I had purchased new breather hoses for both sides. In my experience with older cars, the rubber hoses are hard and brittle. When you start to pull them off of the barb on the breather nipples, they crack or break. A few dollars to replace. AutohouseAZ
Hoselink
I also removed all coils and cleaned everything. I just wanted a clean engine.
Attached Thumbnails Engine Bay Bling-03-new-engine-mounts.jpg   Engine Bay Bling-04-reseal-breather.jpg   Engine Bay Bling-11.jpg   Engine Bay Bling-12-clean-noocks.jpg   Engine Bay Bling-07-new-cps.jpg
Old Aug 25, 2013 | 02:15 PM
cudaized's Avatar
I like a clean engine bay.
Old Aug 25, 2013 | 05:04 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Looking good OP! That sure is some bling, bling
Welcome to the E55 club. Glad to see you're diving right in
Keep the post coming!
Did you put the star back on yourself? My star just came off again last week.
Armani
Old Aug 25, 2013 | 06:02 PM
ddb's Avatar
ddb
2002 E55
Very nice!
Old Aug 25, 2013 | 06:14 PM
ddb's Avatar
ddb
2002 E55
Armani
Thanks, Armani!
Yea, the graphics guy removed the letters and the emblem when I dropped off the cover and gave them to me. My star was already in bad shape. The 12 o'clock point was detached from the circle and it is flaking. I glued the point back on and reattached all the pieces once he was done using 3M double-sided tape. Tedious but it should hold up.
Old Aug 25, 2013 | 09:51 PM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Hmmm...details...where can I get this stuff?
