Purchased Headers, X-Pipe, and Hi-Flow Cats
So I finally pulled the trigger and purchased headers (same as ddb and cudazied), x-pipe, 2 X 300 Cell Hi-Flow Cats, 2 X 45* mandrel bent pipes.
Assuming they actually ship the cats to me (I'm in CA) I got all that for $820 including shipping. I will probable have to pay for sanding the headers flat based on other members experience with this vendor.
1 cat (not 2, just 1) at the dealer was $970 plus tax. Both my primaries are blown.
I plan to: install headers, replace blown cats with hi-flows, delete secondary cats and replace with x-pipe, delete resonator and replace with 45* pipes. Does this make sense?
Anyone got mod friendly NorCAL installers?
What price have you guys paid, or should I pay, for this kind of install work?
I will post pictures when all the parts arrive. Could be a while depending on whether or not I get the cats.
ddb
Post pic of these headers. If they are cheap manifold replacements, keep your manifolds around when you're tired of poor fitment and leaks.
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Having them machined isn't out of the ordinary, but I got ****ed by them sending the wrong one as well. They're cheap for a reason. If you do a search you can find more posts about my ordeal.
Headers
My recommendation to the headers are, check them out for fitment before sending them to be sand. That will prevent costly mistakes later.
Call Corey at Kleemann. They have them for $990.00 they are mid-length and do away with the primary cats all together. The biggest bottle neck on the W210 E55 is at the stock collector. They will even turn off the Check engine light if you send them your ECU. If you are in California it may be difficult to get it smogged though.
Got them from www.mandrelbendingsolutions.com
Also, I don't want to do away with the primary cats as that's what I want for any "visual" inspection.
Not worried too much about quality of parts. The way these cars resale I'd be better driving it into the ground than selling it. Also, my goal is not to spend more than replacment value on mods. By that I mean, 2 cats from dealer =$2k. If I can get all this done for $1k then I'm a happy man, even if I have to replace some of the components in 2-3 years at another $1k.
^That's really true, I am the same way....the way I'm going after all the mods that I put in, I'll enjoy every moment I have with the car and not worry too much. 1K is cheap for all this mod. If you had done them a few years back, would have cost 3k to 4k minimum...I remember the shortie headers alone from AMS were going for 1k or so. The beauty of living in Cali (depending where you live) is that you don't have to worry about the salt in the winter hence you can preserve the car and parts for a long time.
FYI...I did in fact just receive the 300 CEL hi-flo cats along with my x-pipe and 45 degree bend pipes from the vendor I purchased them from even though I am in CA.
Now that I got all the parts delivered, I'm gonna have my guy check out the quality of the parts and figure out the install costs.
Unless the smog guys open your package, I seriously doubt anyone will check and said you can't ship the hi flows to Cali. Crazy not to and miss out on a sale!!
SleepersRock, can you take a few pictures of the 300 CEL hi-flo cats when you put them in, while the car is on the ramp (if you could). I am thinking of going to hi-flos when mine goes and would like to see the fitment from the collector pipe. Thanks!!
I'm also interested in the cats - I have fault codes for both cats being below efficiency. I want to make sure the replacements don't trigger codes, as I have heard that some do.
Here's a Quote
For the installation of headers, xpipe, resonator delete etc., here is a quote I got. Any feedback on the prices would be greatly appreciated:
Straighten Flanges X2: $90
Install 2 Hi FlowCats: $50
Install Headers: $550
Cut and re-weld stock cat flanges on to high flows: $70
resonator delete: $90
Xpipe after deleting secondaries: $120
2 O2 Bungs on Hi Flows: $50
Remove/Replace Entire Exhaust System: $140
Total: $1160
I've never modded performance parts before, so I have no idea if this is good no not. I'm in Nor Cal for reference if that makes a labor cost difference.
Total: $1160
My first reaction: the quote was high. But, I just looked at my receipt and I was charged $416 to remove the resonator and install an x-pipe, as well as removing the secondary cats and installing new, high-flow secondaries. And I supplied all of the parts. I did the header install myself.
My guess is the quote isn't all bad. Can you get it done cheaper? Probably. Maybe it is worth getting a couple more quotes. I wouldn't want the cheapest shop working on my car to save a few bucks (unless their quality of work wasn't a question). I'm glad I was able to do the headers myself. They did kick my butt, however.
You are going to love this set-up!
Best of luck.
ddb
Best of luck.
ddb
Best of luck.
ddb
Best of luck.
ddb
So far its been a headache to try and find someone who can install the headers. Most muffler places around me won't touch them.
Also, how did some of you guys (with headers) find a machine shop to mill or sand the header flanges flat?
2002 E55 AMG Obsidian Black with Charcoal
I called ahead. 2 different machine shops near by. Both said no problem.
One said they could use a milling machine, if it needed it. I knew it did not.
Most shops have a large flat sanding machine with a flat surface. They did not take much off the surface to make True.
My place was cheap compared to other peoples cost. But, I had been there before (resurface fly wheels and other old car engine stuff).
One gets added with install. Was quoted $2 X 2 to add these 02 bungs in.
My indie shop did the headers for me. He told me this was his first on a benz as he has worked on a few muscle cars before....the one thing he did was when he put the flanges on the flat counter top, the flanges were warped pretty bad. I must have got the last one from AMS
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Whatever you do, do not mill them as the flanges were welded to the headers hence they might come apart. You really don't need to cut them flat anyways. Just a good sanding will do the trick!!
Google? Phone location - near by search?
My google search is as follows: machine shop in Santa Clara, CA.
Maybe instead of telling them you have a set of headers which most machine shops unless they deal with automotive products usually don't understand what they are, ask them if they have a large belt sander where they can sand down a flat metal surface....
Did you try Automobile or automotive machine shop Santa Clara? I googled that and found the yellow pages showing several automotive machine shops. I'm not from the area so I can't say which are good or bad.
