Refinished Steering Wheel
Old Apr 28, 2014 | 06:44 PM
RPB's Avatar
RPB
I was very close to splurging on a new steering wheel because the worn two-tone look was making me grit my teeth daily. I took a friends advise and spent $10 for a dye product he recommended before buying a new steering wheel. Sorry for no before and after, but it was bad!!
End outcome:
Old Apr 28, 2014 | 08:34 PM
l pagan's Avatar
1999 E55, 2005 E55 AMG
I like it very nice
Old Apr 28, 2014 | 09:37 PM
Fabio D's Avatar
210 55
What product did you use? looks so good!
Fabio Daniel
Old Apr 29, 2014 | 08:45 AM
eFifty5AMG's Avatar
2004 E55
Originally Posted by Fabio D
What product did you use? looks so good! Fabio Daniel
Also curious, looks real nice!
Old Apr 29, 2014 | 12:11 PM
timmins's Avatar
1999 E55 AMG
I'm also interested.
Old Apr 29, 2014 | 01:39 PM
cg3d's Avatar
2000 E55 AMG
+1, looks good - do they have the same for black? (whatever it is)
Old Apr 29, 2014 | 05:45 PM
RPB's Avatar
RPB
Thanks guys, I am glad it gets your approval.
I would never usually attempt something like this, but it was buying a new steering wheel or taking my chance with this product. I posted a link to it below, I went with the winter white. This stuff is used to touch up car leather by quite a few places, I never heard of it until recently. Lay a light coat down first and then two heavier coats. I covered the stitching underneath the wheel because I wanted to keep it black and really only worked on the front part of the wheel that was worn. The stuff is not sticky when it dries and is super easy to clean, it will not rub off. I completely covered everything in the front of the car except for the part of the wheel being refinished. Leave the windows open too! Please let me know if you have any ?'s. GL!
http://www.ebay.com/itm/M-B-Brillo-N...-/331124638880
Old Apr 29, 2014 | 06:10 PM
eFifty5AMG's Avatar
2004 E55
Originally Posted by RPB
Thanks guys, glad it gets your approval. I would never usually do something like this, but it was buying a new steering wheel or taking my chance with this product. I posted a link to it below, I went with the winter white. This stuff is used to touch up car leather by quite a few places, but I never heard of it until recently. Lay a light coat down first and then two heavier coats. I covered the stitching underneath the wheel because I wanted to keep it black and really only worked on the front part of the wheel that was worn. The stuff is not sticky when it dries and is super easy to clean, it will not rub off. I completely covered everything in the front of the car except for the part of the wheel being refinished. Leave the windows open too! Please let me know if you have any ?'s. GL! http://www.ebay.com/itm/M-B-Brillo-N...-/331124638880
Thanks for the link & info. Will try this for my worn wheel. How well does it match with the rest of the interior?
Old Apr 29, 2014 | 06:55 PM
RPB's Avatar
RPB
Yeah no prob, it matches up nice if you ask me but the wheel does look new now, so there is a bit of an offset. At the end of the day it looks so much better than that worn look and feels better too. Its nice to be able to grip up there without anything peeling off! There were a few other white color variations available for this product, I went w/ the winter white. GL!
Old Apr 30, 2014 | 08:35 AM
cm60k's Avatar
Very nice job MaaaN..,
if you didn't tell you paint it, i really believe you bought it from the DEALER....
ZAYED,,
Old Apr 30, 2014 | 01:15 PM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Looks good. I wonder if it's good also for the front seat. My left side portion of the driver's seat is worn out due to rubbing when coming in and going out over the years. I wonder will this spray bleach out in the summer heat.....all I need is ruining my pants with a stain
Old Apr 30, 2014 | 07:10 PM
RPB's Avatar
RPB
I would contact the mfg of the product first to confirm it will work for this. I'm sure it will as it's a very robust formula, prob worth double checking though. Maybe they can suggest the best color match for your interior too.
Old May 9, 2014 | 04:43 PM
eFifty5AMG's Avatar
2004 E55
Touched up my 43 steering wheel with this stuff too. So much better than the worn out feel/look. But, to be honest, the color doesn't match perfectly, it's a bit more white. However, it looks so much better than before. Doesn't take too long, just make sure everything is properly covered, as it creates a decent amount of chalky dust. Unfortunately, mine was so worn there is a slight texture to it, and it beaded up a little bit in a couple areas. I'm super picky though, but for $10 I can't complain. Did roughly 6 or 7 coats.
Attached Thumbnails Refinished Steering Wheel-image-1347499912.png   Refinished Steering Wheel-image-3292066233.png   Refinished Steering Wheel-image-2033876286.png   Refinished Steering Wheel-image-2940628631.png   Refinished Steering Wheel-image-3731294108.png
Refinished Steering Wheel-image-3802557091.png   Refinished Steering Wheel-image-4235746685.png   Refinished Steering Wheel-image-1635047771.png
Old May 9, 2014 | 04:51 PM
cm60k's Avatar
More white cause it's newer than all whites around,
doesn't matter,,
EXCELLENT work....
ZAYED,,
