rear axle snapped
Old 06-18-2014 | 07:07 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
rear axle snapped
Well found out what the problem is , thought it was the trannny but I guess it turned out to be the rear drivers side axle ..
has anyone had to replace theirs before ..
did you use aftermarket or OEM ..
does anyone know if it has to be e55 specific or can I take one off a e430 or c43 or something or that nature ..
any help would be greatly appreciated ..
Old 06-18-2014 | 11:29 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
Ouch....that sucks. Did the shaft break or the splines?
I pulled my driver's side rear axle out when I replaced the rear bearing back in 02-2012. It wasn't that big of a deal to remove. I can not answer your question if it is a generic shaft, but EPC indicates two different axles. One is bolted and one probably just slips in.
E55 has the bolt in one. Part number: A 210 350 09 56
I suspect that if you find a E430, and it has the bolted in (see picture) axle, then it would work.
Attached Thumbnails rear axle snapped-rear-axle.jpg   rear axle snapped-dsc00229.jpg
Last edited by cudaized; 06-18-2014 at 11:52 PM. Reason: added picture taken in 2011
Old 06-19-2014 | 10:45 AM
MBFLO's Avatar
This is what the mechanic sent me
Old 06-19-2014 | 02:07 PM
SleepersRock's Avatar
2008 W211 E63
I am assuming this is less of a problem than a blown tranny?
I wish I could help (per your other post) but this type of issue is far out of my league.
Old 06-19-2014 | 03:18 PM
MBFLO's Avatar
It's ok man I was bugging out thinking I blew the trAnny but the part had been replaced or rebuilt and should be ready by end of day at cost of $250 total
A lot better then the couple grand I thought it might have been lol
Old 06-19-2014 | 09:55 PM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Cheaper then what they are charging me for installing a set of plugs and wires
Old 06-20-2014 | 11:35 PM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
I can tell 00-02 E430 will fit, but need to know if C43 does..!!!!
ZAYED,,
Old 06-22-2014 | 07:07 PM
RPB's Avatar
RPB
Glad to hear its not your transmission! GL.
Old 06-22-2014 | 08:29 PM
benzokirk's Avatar
'08 E63 AMG
OH! Well that's the good news I was waiting for!! Waaaaay better that than the transmission, for sure! I guess our transmissions are robust, after all, but I'm still getting mine flushed this week!
Old 06-22-2014 | 09:23 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Flushing the transmission would be the last thing I would do, just before jumping off a short pier. There is a filter inside of the trans, just how do you replace this with a new one when you flush, all this will do is move all metal and clutch particulate throughout the trans. Save your dollars and do a drain, filter change and refill ,drive it for 1000 miles then do it again if you cannot drain the converter, other than this if flushing is in your mind be prepared for future issues.
Old 06-22-2014 | 10:26 PM
benzokirk's Avatar
'08 E63 AMG
I think we're exchanging semantics here... I said "flush" when what you described is exactly what my Indie shop suggested. To say "flush" is the quick way to describe "do a drain, filter change and refill"... while one word will suffice, I can see how the exact meaning might be confusing. My understanding is that there is a "filter kit" for this operation that would be used to replace my existing filter.
Old 06-22-2014 | 10:56 PM
cm60k's Avatar
+1,
This tranny always need to be flushed, just be cautious about pilot spacer, oil love to sneaks to TCU...
ZAYED,,
Old 06-23-2014 | 10:57 AM
2008 W211 E63
+2.
Old 06-24-2014 | 11:56 AM
cudaized's Avatar
Looks like the CV joint broke.
Did the mechanic rebuild your existing axle. or did he replace it with a rebuilt one?
Relatively easy repair, but probably gave your gut a huge knot for a while...
Old 06-24-2014 | 07:10 PM
RPB's Avatar
RPB
Originally Posted by cm60k
+1,
ZAYED,,
Correct.
Old 06-24-2014 | 08:06 PM
benzokirk's Avatar
'08 E63 AMG
+1,
ZAYED,,
Will do, Zayed... thanks for the tip!
Old 06-24-2014 | 10:32 PM
cm60k's Avatar
ZAYED,,
Old 06-26-2014 | 10:40 AM
dfreret's Avatar
2001 E55 AMG, 2009 C63 AMG
I had my rear axle bolt shear off and almost lost my entire wheel.
I only found OEM axles, they are specific to E55 and came directly from Germany.
Each axle runs about $1000. Might as well do the wheel bearings (do both sides) while your in there...
Quick Reply: rear axle snapped
