2nd cat/ resonator delete-- pricing?
Old Apr 6, 2015 | 05:31 PM
bluechipbenz's Avatar
2000 e55
What should this cost me? I'm going to add an pipe in place of secondary cat.
I was just quoted at $600usd for stainless steel, $400 for "aluminized steel".
This is all mandrel bend, 2.5 inch piping.
Steve
Old Apr 6, 2015 | 05:48 PM
ddb's Avatar
ddb
2002 E55
I was charged $416 to cut out the resonator and replace it with an x-pipe and to cut out the secondary cats and to replace them with 200 cell cats. I supplied all of the parts.
If they are supplying the parts I don't think their quote is terrible.
Old Apr 7, 2015 | 12:03 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I was charged ~$400 CAD. Including removal of 2nd cats and a 2.5 Magnaflow X-pipe.
Old Apr 7, 2015 | 12:18 AM
giovany2429's Avatar
2002 E55 AMG
I paid $290 for labor/parts. Problem was finding someone willing to remove the cats...
Old Apr 9, 2015 | 03:09 PM
2000 e55
Hey so I think I'm going to pull the trigger here. Found someone that's quoting me $210.
Just to be clear.. All I'm having them do is replace the secondary cat with an x-pipe and delete the resonator and weld two parallel pipes in it's place? We can keep the factory piping between these two items?
Old Apr 9, 2015 | 03:15 PM
2002 E55 AMG
Yes replace secondary cats with the x-pipe. Make sure you use mandrel bent pipes to replace the resonator. you need two. 45 degrees. As for the piping in between i kept the stock ones.
Old Apr 9, 2015 | 05:58 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I just paid $150 replace second cat with straight pipe.
Old Apr 9, 2015 | 06:12 PM
2000 e55
Thanks for the input, that's exactly what I was looking for.
Where would I be without mbworld....
probably much poorer with a worse running car.
Old Apr 9, 2015 | 08:21 PM
2002 E55 AMG
Before you drive off, make sure they double check it for exhaust leaks wer they welded. Also keep in mind that the car will be pretty quiet, almost stock like for the first few hours. After a day or two it should start to sound much better.
Old Apr 9, 2015 | 08:36 PM
2000 e55
Good advice. Why is it that it takes time to "settle"? I would think it would be pretty immediate!
Old Apr 9, 2015 | 08:58 PM
Solo wing's Avatar
Because the car adapts to variables over time. So by installing a crossover, and removing the cats you'll improve repelling exhaust gases.
The ECU, TCU.... adapts to these changes. Although I did this mod more than a year ago, and till this day the car keeps sounding better more than ever.
So it takes time and some driving to fully notice the improvements.
Good luck
Faiz
Old Apr 9, 2015 | 09:34 PM
2000 e55
Good luck
Faiz
Thanks you Faiz.
Old Apr 9, 2015 | 10:18 PM
2002 E55 AMG
Dont get me wrong, you will hear there difference right away but it will get better and better the more you drive it. Take it thru some tunnels let us know what you think when its finished.
Old Apr 9, 2015 | 10:29 PM
2000 e55
oh.. there's a tunnel on the way home from the shop.. and probably the only one i know of in south florida
Old Apr 10, 2015 | 01:07 PM
2000 e55
What a great mod.
Sounds awesome!!!!
Old Apr 11, 2015 | 12:02 AM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Like red wine....it gets better over time I had my mods done a few years back and it sounded even better now then the day I did it....I think I paid $150 back then to cut my 2nd cats and replace them with straight pipes which I bought from eBay. Also guys, remember to take your cats back from the shop as these are worth some money. I sold mine to some dude in Jersey for $150...which offset my installation The guy mention about some precious metal...
And yes...give it some gas when you go thru a tunnel
Old Apr 24, 2015 | 05:49 PM
Dsparx's Avatar
05 E55 AMG
I'm looking for a shop that has a Developer Mode DAS Machine in the Chicago land area that can turn off my primary o2 sensor after I delete the primary cat when installing Kleeman headers and down pipes anyone?
Old Apr 24, 2015 | 05:53 PM
snooozie's Avatar
Cory from Kleeman can remap your ECU for free if you buy the long tubes from them. Just send your unit to him.
Old Apr 24, 2015 | 07:16 PM
Dsparx's Avatar
05 E55 AMG
I spoke with him today he doesn't have a car to plug the ECU in to as of now I'm Looking for someone locally Chicago land
Old Apr 26, 2015 | 10:03 AM
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
Try Fluid MotorUnion in Plainfield. They're my primary Indie Shop, if they can't do it, they can steer you in the right direction, if it's available in Chicago.
