Forward Catalytic Replacement?
....don't your CEL comes on? I'll wait till the CEL light comes on before I do anything...might have bad gas
In that case, drop some gumout in the tank..
I put it up on the lift today, and confirmed it with a rubber mallet. So... after scouring online for 200 cel cats, I wondered which ones to go with. Magnaflow? Seems I can't get to see what they look like on their website. By they way, how does it work, the lower the number the less restriction, correct? So a 200 CEL is better than a 300 CEL?
As far as I remember 300 was the lowest without triggering an error code. Someone might chime in.
"If you have a 2004 or newer vehicle and are worried about setting off the check engine light I would recommend searching our other auctions for the Magnaflow 99656HM. Which is the same style cat that is a little thicker that has a heavy metal substrate. If your vehicle is 2003 and older the cat in this auction will work fine." So there you go.....
I would put these on mine if my primaries go for sure.
