Factory M113 Fuel Injector Part#
Old Jan 26, 2016 | 06:40 PM
Tanderso's Avatar
2002 Mercedes-Benz E55 AMG
Looking for the part# for the fuel injectors for an M113 engine.
Looking to buy a nice cleaned/balanced, and flow tested set if anyone has a lead.
Thanks.
Old Jan 26, 2016 | 06:52 PM
cm60k's Avatar
Do you have Green or Yellow/Beige injectors..?
ZAYED,,
Old Jan 26, 2016 | 07:25 PM
Tanderso's Avatar
Mine now are yellow/beige. 2002 E55 AMG.
Thanks.
Old Jan 26, 2016 | 07:54 PM
cm60k's Avatar
Beige/Yellow (283cc):-
OEM #: "113 078 03 49"
Bosch #: "0280 156 074"
ZAYED,,
Old Jan 26, 2016 | 09:08 PM
Tanderso's Avatar
Awesome!
Exactly what I needed, thank you.
Old May 10, 2021 | 10:20 PM
ChrisVannoy's Avatar
2002 Cl500
What’s the difference between the two ?
Old Apr 6, 2023 | 08:59 PM
6spd's Avatar
00 ML55, 00' E55, 03' CLK55
Beige one is 283cc and green I think is 224-7cc? I can't remember but the beige have a higher flow rate by quite a bit.
Old Jul 27, 2023 | 11:05 AM
Alpina7's Avatar
2005 Mercedes S600
If you have biege can you replace with the greens? plug and play? just curious
Old Jul 27, 2023 | 12:19 PM
6spd's Avatar
100% plug and play. In your case though why would you want to run smaller injectors?
Old Jul 27, 2023 | 12:38 PM
Alpina7's Avatar
2005 Mercedes S600
i havnt even looked at mine to be fair. good to know though!. now i just want to do that TB mod you did
a good write up would be very helpful. or even a kit
cheers
Old Nov 23, 2023 | 09:53 AM
bigkermw211e55's Avatar
2004 W211 e55 amg / 2003 w163 ml500
M113 fuel injectors
What’s the part numbers for the green ones ?. I have a 2003 ml500 with m113 engine
Below is the part numbers for my injectors
part # A1130780249 / 0280156016
Old Nov 25, 2023 | 09:45 AM
Tall Giraffe's Avatar
2001 E55 OMG
0280155839 are green for M113 but have a greater lb and flow cc.
