Transmission leak (Oil pump/Governor) - Fixed
Old Jan 4, 2017 | 02:30 PM
Jan AMG's Avatar
The best or nothing
Thumbs up Transmission leak (Oil pump/Governor) - Fixed
If you discover small drips of oil coming from the front of your transmission it could be a leaking oil pump/governor seal. It is an easy/moderate fix.
While there, replace the output bearing and its seal as well, it will be worth it and it all costs under $70. Some labor is involved of course
When putting everything back together, use new installation material. Good luck!
Attached Thumbnails Transmission leak (Oil pump/Governor) - Fixed-img_3758.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3759.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3761.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3765.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3769.jpeg
Transmission leak (Oil pump/Governor) - Fixed-img_3771.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3772.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3774.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3779.jpeg   Transmission leak (Oil pump/Governor) - Fixed-img_3783.jpeg
