Which battery for a 2001 E55 AMG
Old Dec 19, 2022 | 07:54 PM
mac2001's Avatar
E55
Never seen a battery last as long as this one, especially considering the car is rarely driven. But it’s time for a new one. First thing is trying to get the rear seat out of the way - I try to raise the clip while lifting the rear seat, but it seems rather stuck. The clip on the left side lifts easily. Only the one on the right side seems stuck. I suppose I will just keep trying to free it, perhaps with a long screwdriver for leverage. Any suggestions?
Which is the strongest battery to get? Should I be looking at amp/Hour, or CCA (cold cranking amps). Interstate website shows 3 choices, with most expensive at $260 with 3 year warranty. I do not see any a/H specified.
I won’t do the work, I’m taking it to the local shop that has done routine service (they seem to know the W210 chassis), but maybe new techs there, so I need to be informed about the procedure prior to letting them touch the car. Seems an important procedure is jumping the car prior to disconnecting and removing the existing battery. Does this eliminate any need for reprogramming?
Old Dec 20, 2022 | 10:07 AM
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
I run the interstate replacement in all 3 of my e55's. As far as the seat goes i always push it down, pull the tap up then lift the seat.
Old Dec 20, 2022 | 12:41 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
You want an AGM battery rated at 900 cca. The last one I bought at Sam's a couple of months ago cost me approximately $160. I forget the size but that information is available on the internet. It is one heavy SOB!
Be sure the key fob is not in the ignition when you connect jumper cables or when you connect the new battery. You will need to reset all windows, the mirrors, the sunroof, and you'll have to key in your radio code.
Also, you will get an ESP failure light on the instrument cluster. You will need to turn the steering wheel lock to lock several times to reset the steering angle sensor to make the warning light go away.
Edit: I believe the battery size is an H8 but please verify.
Old Dec 20, 2022 | 11:04 PM
mac2001's Avatar
E55
Turbo1K - I will give that seat another try. Thanks for the tip.
bbirdwell - Agree that the AGM is easily the best choice. Got it, do NOT leave key in the ignition. As for resetting systems, is that going to be necessary if we keep 12 Volts powering the car at all times?
Old Dec 21, 2022 | 10:20 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Originally Posted by mac2001
<snip>
It should work out for you. I once read a reason why not to do so but I cannot remember the argument against having a 9-12 volt battery tied into the system. In any case, I wanted you to be aware of the worst-case actions. The ESP failure light startled me a bit the first time I changed a battery...
Old Dec 21, 2022 | 11:41 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
H8 size AGM 900 CCA at Walmart for $169:
EverStart Platinum AGM Battery, Group Size H8 (12 Volt/900 CCA) - Walmart.com
Old Dec 22, 2022 | 09:12 PM
mac2001's Avatar
E55
Everything went quite easily. 2 person job, unless you are Hercules.
Old Dec 22, 2022 | 09:15 PM
E55 KEV's Avatar
Veteran: Air Force
Damn, I must be Hercules LOL
