nos is in and I'm ready to rock!
Please give us ALL the details....can't wait to see your dyno numbers....Gray
Built my own system, I've got .29's in there right now but have a dyno scheduled for the 19th! then I can ajust up on the jetting i know the guy in texas says he's using a .31 so we'll see acording to the A/F's did a test run last night everything went well. since its probrably around a 35hp shot right now its alittle mild(especially going through the filters restricts it) but the mph sure started going up faster! if it would ever stop Fu$k'n raining here in oregon I'd go to the drags! I can take it all out and hide the nitous line in about 20 min for trips to the delership.
What were your A/F's with .029's?
You may want to invest in a bottle heater/cooler as bottle temp has an amazing influence on pressure and HP....e-mail me and I can give you the temps to bottle pressure and jets to crank HP.
Are you using any accessories to retard timing or add fuel?.... running 100 octane has nearly the same effect on detonation as retarding timing a few degrees...I would use 104 but can't reliably get it at this point.
Eagerly await your results at trasck and dyno.....spray and pray..
Gray
Gray
Awesome setup by the way
and it has to pass through the air filter also so hopefully thats enough.(I have had some experts check out the set-up and they seem ok with everything just need to dyno to fine tune)
April 9 Test & Tune and High School Series
Gates open 8 a.m., racing begin at 9 a.m. Open to all classes.
Racer $25 (High School $25), Adult $10, Kid 6-14 $5, under 6 Free.
April 10 VP Racing Fuels Championship Series. Anyone can compete.
Gates open 8 a.m., time trials begin at 9 a.m., eliminations at 1 p.m.
Racer $35 (Super Pro $40), Adult $10, Kid 6-14 $5, under 6 Free.
See you there?.
See you there?.
BUT MAYBE PIR OR LATER AT WOODBURN!hilsman chk. your pm
