How's Kleemann LSD?
Old Apr 11, 2005 | 04:09 PM
JLee81's Avatar
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
How's Kleemann LSD?
No noise? How does it perform in the straight line and around corners?
Old Apr 11, 2005 | 04:43 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just love it....
I actually wonder if I would have been bummed out with an AMG LSD rear with only 30% lockup as I still squeal the tires off the line (well PS'2s) with 60% lock with Kleemann......but it's a little squealing and the best part is ESP of death rarely comes on anymore.
Only time I have ever heard the famous LSD Klunk was once when going around a 90degree corner such as an intersection and I punched it hard to get into traffic.....one real wheel must have lifted and really tried to spin....contacted Brandon at Klemann and was told it was not that big a deal, but try to avoid.
Here is the response from B man....gosh I love those guys.
This noise is somewhat inherent to the design of the mechanism in the
rear. The mechanism is always applying outward force to the two
planetary gears, the force is determined by the spring pressure in the
clutch mechanism. It is possible to overcome this pressure if the input
into the rear exceeds the clamping pressure. During this time one of
the wheels will slip in relation to the other until the the input force
becomes lower than the clamping force, then, clunk. The clunk comes
from the tolerance in the clutch mechanism and a large axle pin that
passes through it for the smaller planetary gears. I dont think you
have much to worry about- that said, avoid making it happen if
possible.
Old Apr 11, 2005 | 08:42 PM
JLee81's Avatar
I heard that there is a special lubricant for the noise. I don't know if kleemann supplies one.
Old Apr 12, 2005 | 09:15 AM
Gid_E_Up's Avatar
2005 Kleemann Stage 3 E55
Absolutely required with higher HP.
Old Apr 12, 2005 | 11:52 AM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
Originally Posted by Jakpro1
Just love it....
possible.
Hmmm...don't worry about it, but avoid at all costs!!!
Old Apr 12, 2005 | 11:59 AM
Jakpro1's Avatar
Yeah, I know that sounded weird. Just a real political way of saying....if you keep doing that s)*&(t, you're gonna roach the gears in the LSD/REAR, but for now, you should be fine.
Old Apr 12, 2005 | 12:43 PM
M5KILLR's Avatar
evo sells the lsd for 2300. is that what you all paid? also evo has there own for 5200??? pm your price if you dont want to post and who to contact.
Old Apr 12, 2005 | 01:06 PM
Jakpro1's Avatar
Yeah, same price Pete...2300$
I am thinking of someday bringing up the gear ratio on the 55 a tick...think that will be best thing I can do to increase performance for the cost.
Don't really give a rat about top end (170-185mph) as I know that would come down....would love to get a little more kick on the low end without hurting the drive train too much. EVO has that right??
Old Apr 12, 2005 | 02:24 PM
cte430's Avatar
'07 Porsche 997TT
My thoughts as well. That's one mod that would make me kind of nervous. I think I'd stay with the less aggressive 30% you get with the AMG even if the performance may not be up to the Kleemann's.
Old Apr 12, 2005 | 02:34 PM
Jakpro1's Avatar
New rear runs 3500$...Would be pissed, but not end of the world for me.
If you ask me...the real daredevils are the Nitrous guys....I am in awe of someone with the Kahunas to mess with a 30,000$ motor with something that can be risky like Nitrous...it would be obvious from what I hear, to the techs, if you burnt a piston leading to catastrophic damage....I am all for them modding, but just past my "ball level" at this point.
Sure in awe of them though....maybe someday.
