Mission Accomplished: The 2005 Steering Rack Is Now Installed!
BMW M5, Porsche 911, Mercedes-Benz E55
As I described in my previous thread, I've been extremely happy about the transformation that's occurred as a result of STEP 1: installing the CLS 55 front shocks and lower control arms (containing the latest bushing specification).
I've now finished STEP 2, the installation of the 2005 E 55/CLS 55 steering rack with its quicker ratio (i.e. 14.8:1 vs. 15.3:1).
First impressions: the steering is quicker, more responsive, faster, and lighter. The car feels yet even more agile and nimble (i.e. as compared to the noticeable improvement discerned after STEP 1). Quick 90 degree turns are now taken with effortless ease. Tightening one's line mid-turn is now a joyful experience. It's as if I don't have to fight the car nearly as much.
The only complaint as to do with the lack of overall steering feel/feedback. The typical Mercedes-Benz steering numbness is still (expectedly) present. While the steering is now reasonably accurate, it still doesn't convey much in the way of detail. The problem is that my point of reference is my 2000 BMW M5 with Dinan S2 mods. That car also has 9.5J x 18" OEM rear wheels fitted with 275/35/ZR18 PS2s up FRONT (i.e. a lot of front-end footprint makes for much front-end bite). As one would expect, it's steering response, feel/feedback and turn-in are sportcar-like. Even though that car has a recirculating ball system, its steering simply talks to the driver. A lot of this might have something to do with BMW's philosophy in the toe-out setting department. All of these things add up to highly involving, extremely quick, and far more responsive (and less wooden-feeling) steering on the M5.
However, my new-found steering on the E55 provides a markedly dramatic/pronounced improvement to the car's day-to-day driving experience, something that almost any driver would easily notice. While I have heeps of praise for my M5, my E 55 is definitely no longer a complete slouch in the steering department!
Originally Posted by W211 Ryda
Where did you get steering rack swap done? MBSD?
time of installation
would it be easier to have all changes done at once, or are the ares that have to be changed totally different so that the procedure's charges would be separated. In other , maybe clearer words, when the shocks and arms are changed, does it expose the steering rack and make that change easier, or is it a totally unrelated area.I understand that they're both under the car.
also, again, those arms will not be available until june or july, right?
My contact at AMG recommended that I get the work done in two distinct phases, so that way I could measure/quantify/separate-out the change in feel firstly as a result of the CLS 55 front shocks and latest-version CLS 55 lower control arms (with the most current bushing compound). Knowing the expense of the steering rack, my AMG contact suggested that I only retrofit the 2005 unit in the event that the shocks and control arms didn't make enough of an appreciable change in the steering feel and handling dynamics. The first phase definintely helped out a lot. However, being the perfectionist that I am, I felt compelled to go the entire distance. I'm certainly glad I did!
for those of us who don't have friends in the right place, what would be the total cost of parts? labor in new orleans is about 80/hr
