any diy tips for changing d2s bulbs?
Thanks!
Thanks!
hey, they are for the bixenon, i wanna see how the 6000k headlight look first then decide the foglite hid
any tips guys?
any tips guys?
fazooley
fazooley
Some HID retrofit kits are wired directly to the battery, with a relay to turn on/off. Is this how you hook yours up, or is it one of those plug-n-play deal using existing wiring harness? The relay wire harness will draw power directly from battery, thus eliminating the problem you described. I think.
But then do you also need all that horsepower in your E55?
