Lower your E55 by 20mm/ 0.8" for 80 cents!
Rating: Thread Rating: 5 votes, 5.00 average.
Old Aug 22, 2012 | 09:15 AM
  #201
gazosnic's Avatar
e46 m3, w211 e55
Couple questions... do you bend it lower to the ground or higher?
Also would you need to put this on a lift to get access or could you reach it by taking off the back drivers side wheel?
Old Aug 22, 2012 | 09:38 AM
  #202
Zishan's Avatar
E55(gone), Tesla Model S P90DL, MB GL 450
No, you bend it towards the rear. This pic below, imagine you are laying on the ground, and you slide under the car from the rear bumper(head first). You bend this bracket towards the rear of the car. Once you find the bracket and see how people mod the holes(move them rearward) it will make sense.
Yes, you can access the part without a lift. I used my aftermarket jack, lifted the rear drivers side, placed a jack-stand under the car, and slide under the car from the rear.
The bracket is going to be slightly towards the drivers side, behind the exhaust piping(drivers side exhaust piping).
Hope this helps...
- Zishan
Originally Posted by Zishan
I did this tonight as I was sick of the car looking so high. When it's raised, it actually looks/resembles a C-class in my opinion....you know, the C230 sport or the like.
The rear is noticeable, but the front is barely even lowered. I'm going to try having Stardul lower it via Star now.
Anyways, I hope no one minds me using their pic, but I bent the bracket back. I used a large wrench and only bent it 3-5mm's.
The pic/laying directly underneath the car with the 2 bolts facing the ground. Re-drilling the holes essentially moves it back. I just bent it slightly back by placing the wrench where the red circle is and pushing it back in the direction of the red arrow/towards the rear of the car...as illustrated here:
Old Aug 22, 2012 | 11:16 AM
  #203
///Molloy's Avatar
2004 E55, 2011 G55, 2007 CLK63, 2012 E63, 2019 G63
This makes sense to me now. I was trying to bend it directly down, and obviously failed. Bending it "up" and "back" makes sense to me now, given the configuration of the height sensor arm up above.
I am going to go the STAR route probably this weekend.
for gazosnic's benefit - no, you cannot access this via the rear wheel well. You literally need to be totally under the car, facing the diff. tight little spot down there.
Old Aug 22, 2012 | 11:17 AM
  #204
gazosnic's Avatar
e46 m3, w211 e55
That def helps thanks! Last question... where do you recommend i place the jack stand? Typically I lift the car with my racing jack on the stock jack points. Is there a recommended spot for the stand once I have it up?
Thanks!
Old Aug 22, 2012 | 11:37 AM
  #205
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
I've had that same question since I bought the car and no one seems to be able to answer it well....
https://mbworld.org/forums/w211-amg/...ackstands.html
Old Aug 22, 2012 | 11:45 AM
  #206
Zishan's Avatar
I used the rear lower control arms....placed the jack stand there, but didn't place any weight on it. It was more for just in case. I was under there for literally 2 minutes so I felt my jack was enough. But good question...I'm curious too.
Old Aug 22, 2012 | 02:02 PM
  #207
gazosnic's Avatar
e46 m3, w211 e55
hmm... seems like there has to be a better solution. Wish I had access to a real lift for this.
Old Aug 22, 2012 | 04:29 PM
  #208
DGSU4EA70's Avatar
2005 E55 (FST N OC)
MB Mechanic + STAR = FREE!
Old Aug 22, 2012 | 10:01 PM
  #209
HeissRod's Avatar
STAR + washer method = better
Old Aug 22, 2012 | 10:28 PM
  #210
Zishan's Avatar
So.......since you're a "MB Mechnic"......why not enlighten us as to where the appropriate place to use jack stands?
Old Aug 22, 2012 | 10:49 PM
  #211
gazosnic's Avatar
e46 m3, w211 e55
Sucks for us who don't have friends w star
Old Aug 23, 2012 | 06:13 AM
  #212
Turbotalon92's Avatar
E55
Hey guys, to do my rear, I just bought a set of drive up ramps from autozone and had PLENTY of room. Placed behind rear wheels, reversed up, and bam, easy access.
Old Aug 23, 2012 | 09:34 AM
  #213
gazosnic's Avatar
e46 m3, w211 e55
I tried that and it kicked them back.... was to afraid to try that again. Probably need better ramps. I may try and build some ramps instead with a longer 'runway'
Old Aug 23, 2012 | 10:39 AM
  #214
E55
The ramps I got have rubber feet that hold them tight, $38 at just about all autopart stores. They are black plastic and rated for 16,000 pounds.
Old Aug 23, 2012 | 10:45 AM
  #215
HeissRod's Avatar
Use your floorjack to lift the car and then just put the ramps under the tires.
Old Aug 24, 2012 | 01:24 PM
  #216
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Im personally NOT a MB mechanic but I built a few hotrods in my day! My good friend owns/runs a reputable shop here in the OC, that's why it was FREE.
Old Aug 24, 2012 | 03:50 PM
  #217
HeissRod's Avatar
Completely off topic, but were is the original size pic of your avatar.....?
Old Sep 3, 2012 | 10:57 AM
  #218
gazosnic's Avatar
e46 m3, w211 e55
Ok so finally did the rear myself as well. It was super easy. If anything took the longest to find it and adjust back and forth to desired height.
I just used a large flat head screw driver and slightly pushed on the silver metal bracket toward the rear of the car. I mean SLIGHT... at first I lowered it back down and the rear was tucked! lol... Wasnt to my taste so i bent back a bit the other direction (toward front of car) and got myself a mild drop to better match my front.
Below is a pic of the silver bracket to bend and the resulting pic of my drop (note I went for a very mild drop - you can go tucked if you want very easily).
This is a 5 min mod... I dont see the need for links. The only product I see as an advantage here would be the ELM so you can adjust from inside the car on the fly.
Bracket:
Lower your E55 by 20mm/ 0.8" for 80 cents!-6ec34de5-bb89-428a-9ef8-a87dacc4861c-2543-000003552f281371.jpg
After pic:
Lower your E55 by 20mm/ 0.8" for 80 cents!-05de08f4-2483-4a73-94c0-d6b87066c756-2543-0000035536e7d123.jpg
Old Jan 1, 2013 | 11:47 AM
  #219
gazosnic's Avatar
e46 m3, w211 e55
I did it. its the bracket that holds the sensor if that makes sense. It works, but it isn't really precise so you have to play w it until you are happy with the drop. Id actually recommend using links or something similar in the rear to better control the exact height you are looking for.
Old Jan 1, 2013 | 11:48 AM
  #220
gazosnic's Avatar
e46 m3, w211 e55
Originally Posted by chawkins2001
Has anyone actually done this for the rear? What exactly are you bending, the silver bracket or the sensor arm behind the silver bracket?
Here is a write up i did with pics of the rear bracket... hopefully this helps a bit.
http://www.amgpost.com/showthread.ph...ailed-pictures)
Old Jan 1, 2013 | 12:00 PM
  #221
gazosnic's Avatar
e46 m3, w211 e55
I just used a long screwdriver for leverage.... really you can use anything... if i remember correctly you basically are pushing it up / toward the rear of the car.
Old Jan 1, 2013 | 12:02 PM
  #222
gazosnic's Avatar
e46 m3, w211 e55
Yes - thats it from what i recall.
You pushing in the section with the red dot?
Old Jun 25, 2013 | 02:51 AM
  #223
BlueML99's Avatar
'99 ML320, '06 E55
How has there airmatics been holding up with this mod? (those of you have has done a while ago). Has anyone ever tried this mod in combination with lowering links? If so what whas the outcome? Wondering if it will slam the car or if it can even be done.
Old Jun 25, 2013 | 02:42 PM
  #224
HeissRod's Avatar
No issues here after 2+ years.
Also, why would you need to combine this with lowering links?
Old Jun 26, 2013 | 02:14 PM
  #225
Alan_G's Avatar
E320
Anyone know of a shop in OC that would do this for me? Don't want to mess anything up and would rather have someone that knows what they're doing.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
