Lower your E55 by 20mm/ 0.8" for 80 cents!
I lowered my front with 4mm of washers and it actually seems like it raised the rear a bit.
After 75mph the car goes into its lowest ride height setting. it doesnot progressively lower as the speed increases. this ride height can be replicated with the STAR DAS while doing a alignment job at the dealership.
Originally done by guys like EPower and tbone (E500 from E-Class Forum) ...thanks a lot fellows!
For those of you who would rather keep the 2 grand for two sets of new tires or an "inexpensive" diamond ring for your lady, here goes: lift the front end with a jack to expose the aluminum suspension and air spring (no need to remove the wheel). You will see a double lever sensor attached to a metal bracket at the top. Undo the top 10mm nut and remove the small grey bracket with the articulated sensor still attached by a ball-joint. Place 5 to 6mm / 1/4 " worth of small washers under the bracket and re-fit in the reverse order. There isn't enough thread to place any more washers or the nut will not thighten up and you might strip it. Those 6mm will translate into 20 mm drop at the front wheels when you turn on the engine!
In essence, you are fooling the Airmatic DC into believing that the car is sitting 20 mm too high and it will lower itself by the self leveling suspension and stay lowered for as long as the washers are in place. This is a completely reverseable mod. I read the 2002/2003 thread last night, could not believe my eyes and did the job first thing this morning. I now have a totally balanced front and back with exactly identical clearence around all four weels. Handling and turn in has improved as the heavy front of the car dropped the centre of gravity by 20mm, but the ride comfort is unchanged. Once inside, you will immediately notice the new lower front aspect of the car and reach for the seat adjustment to stop "leaning forward".
You can also raise the car by the usual "Raise" button and, stangely enough, it goes up to within 10 mm (rather than -20mm) of it's previous "SUV" setting, so it finds another 10mm somewhere.
This is by far my best mod yet!
The best things in life are free or no more than 80cents!
Did a quick write up with detailed pics here:
http://www.amgpost.com/showthread.ph...s)&p=16#post16
Of course on the first try I screwed up both the front and rear.
Rear- pried the bracket towards the front/ground and it went higher. Easy fix and actually got it back and to where I wanted it by hand. <1 finger gap now
Front- Stacked 3mm of washers on each side and started the car. "car too low" in red. Upon inspection I had one arm flipped the wrong way but I had no idea which one. LOL. Got it figured out and we're at <1 finger gap now.
Uploaded with ImageShack.us
I then tried to take some video of me bending it with a screw driver. This would be MUCH easier on a lift. I was not able to make any progress on it, and feared forcing it and breaking it. Fu_K.
http://youtu.be/PFoQevCkc3s
The rear is noticeable, but the front is barely even lowered. I'm going to try having Stardul lower it via Star now.
Anyways, I hope no one minds me using their pic, but I bent the bracket back. I used a large wrench and only bent it 3-5mm's.
The pic/laying directly underneath the car with the 2 bolts facing the ground. Re-drilling the holes essentially moves it back. I just bent it slightly back by placing the wrench where the red circle is and pushing it back in the direction of the red arrow/towards the rear of the car...as illustrated here:
