Subwoofer install
The audio forum hasn't been much help and I haven't been able to get a peep out of Scorchie. Everything that I have checked 3.5v or other odd voltages. I emailed MBenzNL for help finding a wiring harness using MB wiring and plugs, this would be ideal but have not gotten any info regarding that set up.
If anyone has any info or knows of a good website which might point me in the right direction I certainly would appreciate it. I've got a JLA 10W7 and a Monoblock 500/1 just itchin to get turned on.
As far as working on my own cars, I have done it all my life, but this MB is really perplexing. Everthing is computerized and low voltage. The fiberoptic network is difficult to understand without the apprpriate manuals. (that I don't have) BMW forums have all the wiring diagrams for their vehicles readily available and I've used them several times on my M3. Very handy!
According to JL Audio triggering can be done by signal sensing circuit but it must be a midrange signal and if you're using signal to the rear base speaker it won't come on. This seems ludicrous when it's a monoblock BASS amp that will never to connected to anything but equalized bass signals. GO FIGURE.
I'm still working on it and next step is to go to my MB guru that owes me a favor. He doesn't do sound systems but he might be able to find a 12v switched line in the rear of the vehicle. Thanks for yalls help.
(j/k)
Maybe this link will help you further. Click me
@Ricky
I can't believe you didn't find/post this hint.
<duckundschnellweg>
(j/k)
@Ricky
<duckundschnellweg>
If one were to go to the trouble of developing a special harness, knowing full well that the turn-on signal is needed and fiber optic turn-ons are the MB norm, would it not be sensible to mention that when offering a solution for AF equipment. I choose to give him the benefit of the doubt in this case. $0.02
Does anyone know where Scorchie is?
I just returned from the dealer and as far as my service advisor knows the closest switched 12v line is in the back seat cigarette lighter. Everything is low voltage and is connected to the computer. My next project is to run a line from the center console to the trunk. I'll let you all know how it turns out.
Couldn't find any switched 12v line going to the factory amp, Nav, or the fuse panel? If not, how about just wiring a relay to a switched low voltage in the trunk area and use that as your 12v remote?
Low Voltage Trigger
Provides 12 volt 500ma output from a low current source...
converts 5volt turn on to 12 volt turn on.
http://www.installer.com/acc/index.html
This may be simple for some you all but for a electronically challenged **** DOC I needed a simple premade part. It's much cheaper than a JLA LC6. Now I just need to finish my custom 1" MDF enclosure.
