Why does my car skip side to side?
AMG 55, 335i, Mini Cooper S
I have noticed when I'm driving at freeway speeds and I hit bumps or dips in the road my car sways or skips side to side but not up and down. The Koni's and H&R springs are only a little over a year old. I do have the rear Koni's set on medium and the fronts and soft, not sure if this is causing the problem. It has been a problem for a while even after getting new tires. I'm wondering if it might be an alighnment problem because I have never done it since I lowered the car. The car drives straight but it just tends to sway left and right in a smooth way but not in a normal way.
Please help
Please help
04 E500 Brabus Wagon
side to side
When I used to autocross a lowered and tight 240Z with fat meats, and when I used to run shifter carts I often felt what you describe. The problem is likely due to not enough suspension. By that I mean everything is too tight, in racing terms they would say take a few turns out of it, so the suspension can better do its job. In your case I not sure what your options are to get more suspension into your car.
BTW where did you get your roof wing?
Mario
Originally Posted by The Godfather
Tires
![word](https://mbworld.org/forums/images/smilies/werd.gif)
