Supercharger chirp worse since dyno......
Old Nov 20, 2005 | 10:46 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
So friggin hard to describe, but when you guys slowly accelerate from a stop light, how bad would you rate your "lunge"? Ahhhh, this is probably a waste of time as each guys sensitivity is different. Just seems like since my dyno run, the squeal is pretty darn loud now and the surge is pretty pronounced.
I swear it feels sometimes like when she changes gears under mild driving accel, it feels like someone is tapping the car in the rear....are you guys experiencing surge at all on acceleration. Not goosing, just wimpy stuff....
It is almost as if the car is quickly cutting out to change gears.
Gonna try the stop squeal on the super charger clutch, but of course if I go in for service, I bang into the mod issue with dealer from hell around here.
Such is life in the mod world I guess.
Thanks for any input.
Old Nov 20, 2005 | 10:52 PM
MB Fanatic's Avatar
4 wheels
It would be nice to see an aftermarket belt that would help decrease or eliminate the chirp that we all are experiencing.
Old Nov 20, 2005 | 10:56 PM
Jakpro1's Avatar
Okay cool, so we are all chirping.....(well not just me)
Can you really feel it when blower engages? How bout gear shifts in S mode...is it pretty hard. C mode seems pretty smooth, but S can be like getting kicked in the back sometime.
Old Nov 20, 2005 | 11:32 PM
MB Fanatic's Avatar
4 wheels
I can hear it at idle (somewhat) and at WOT. I guess its not as bad as yours.
Old Nov 20, 2005 | 11:35 PM
jordan's Avatar
so try some belt dressing to get the belt to tack up a bit.
jordan
Old Nov 20, 2005 | 11:41 PM
04E55 AMG's Avatar
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Known problem that MB says we need to live with (sad but true for a $90K sedan). All the 55K motors will chirp, just a matter of time.
Yes, you can fix it but it will come back.
After some time you get use to it
Old Nov 20, 2005 | 11:42 PM
MB Fanatic's Avatar
4 wheels
yeah I just kind of ignore it now. I still say an aftemaket belt might help or cure the problem.
Old Nov 20, 2005 | 11:44 PM
Jakpro1's Avatar
Okay cool....no biggee. Chirping it is.
Freaky. Can't wait someday for turbs......then I guess I will be b itching about lag....always somethin.
Old Nov 21, 2005 | 01:57 AM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
I notice the "kicked in the back" in first gear the most, second gear somewhat, and third and above very little.
It seemed counter-intuitive to me, but my theory is that because the engine revs freer in first gear and the time it takes for the supercharger to engage is relatively constant, the RPM stumble is more abrupt in first gear versus third. Another factor is that in normal driving, at a given load the supercharger engagement will occur at a higher RPM in first gear than in a higher gear.
That would be my guess as to why you notice it more in S than C, it's occuring in first in S and in second in C.
For just driving around in M mode, I try to get through first and second before the supercharger engagement, then bring on the throttle once in third.
Oh ... and I have grown to love the chirp ... it's my signal to stand on it :-). I gave up on the whole stop squeal thing.
Old Nov 21, 2005 | 09:57 AM
Marcus Frost's Avatar
Real Cars
There is a TSB about this of course, and MB's stance is "there is a fix in the works" - that is why most MB dealerships won't try to fix the chirp - they can't fix it permanently and are being told by MB to wait for the fix.
-m
Old Nov 21, 2005 | 11:30 AM
04E55 AMG's Avatar
-m
My gut tells me that with the next gen engines not being SC, they will never have a fix
Old Nov 21, 2005 | 12:11 PM
Jakpro1's Avatar
So last thing....now that we've resolved (that it won't be resolved) the chirp issue.
Are you shifts in S mode real punchy and rough. (1st to 2nd....little better 2nd to 3rd) I have it in C mode and she starts nice and smooth in 2nd and shifts real smooth, but S is a trip. Always been this way, but as I mentioned after dyno, it seems worse.
Just wanna make sure not having a little tranny trouble.
Old Nov 21, 2005 | 12:29 PM
WayneE's Avatar
'72 Suburban
That's their fix - drop the SC
I had an SLK32 that had a really bad SC chirp. This was back in 2002, hard to believe they couldn't fix the problem in 4+years.
Old Nov 21, 2005 | 01:33 PM
BenzoBoi's Avatar
Super Moderator
W221
Strangely I felt this surge come on when I came to a stop at a light. I would come to a completely stop at the light, and then out of nowhere th car just lunged ahead. I had to slam the brake pedal to stop the car. It was really weird. It's happened twice since I owned the car...weird...
Old Nov 21, 2005 | 02:23 PM
MBAMGPWR's Avatar
W215 CL600
I've just learned to live with my "chirp". At least I know the SC is engaging.
Old Nov 22, 2005 | 08:37 AM
merc655's Avatar
a few...
I have had mine really bad lately. It will give a huge kick in the back after you get on it enough to just about wind out 1st and it wont shift to 2nd except for well after you are off it. I have had the lunging too.
I just live it with it for now, I think I will try the fix that was on this board a while back but otherwise I guess thats just part of having a 55 engine with a SC.
Have any of you had any steering pump noise or anything like that? just wondering becuase the past two days I have noticed a noise that seems like it is from the steering pump.
And if anyone finds a cure for the chirp, post it up immediately....
Old Nov 22, 2005 | 08:52 AM
Vetluver's Avatar
SL 65 AMG and E63s AMG
You obviously don't have a good enough subwoofer.
Crank up the tunes and you won't hear the extraneous noises.
This the only way I can stand my wife's M3 Convertible. It's rattles like a bag of bolts. Drives me crazy.
Old Nov 22, 2005 | 11:06 AM
mclarenm8d's Avatar
Hmm ... I'd guess that the S mode shifting you note is from transmission adapting to its run on the dyno and being more aggressive. I have no basis for saying that, other than it might be possible and would be a less expensive explanation and less of a hassle than the alternative of tranny trouble.
If I keep throttle constant and the supercharger isn't engaged in first gear, as the second gear shift occurs the supercharger will often engage because of the change in engine load. This makes the shift feel rough to me.
- First gear/no supercharger shifting to second gear/with supercharger
is much rougher than
- Second gear/no supercharger shifting to third gear/with supercharger
So ... C mode definitely stands for "Comfort" for me. Although, I drive mostly in M mode.
Old Nov 22, 2005 | 11:09 AM
mclarenm8d's Avatar
Steering pump noise - I had the idler pulley close to the steering pump changed, and I also had the idler pulley on the passenger side changed. Due to the location of the noise, I thought it was the steering pump going bad but it turned out that it wasn't.
I also have fresh belts. I got into my CL55 used, these pulley and belt fixes occured at the ~30K mileage mark.
But, I forget the particulars, I have a tandem steering pump/ABC pump that may be different from the E55 config (??).
Old Nov 22, 2005 | 11:38 AM
merc655's Avatar
a few...
Thanks for the info. I thought it was the steering pump but I am guessing you have heard the same thing before. I will talk to my Serv Manager and have him fix it this weekend. It just has gotten worse in the past few days and I was just thinkin what could possibly be wrong.
