Caliper Paint Q&A
Old Jan 11, 2006 | 10:43 AM
JokerzWld's Avatar
2014 GL 350 on order
Cool Caliper Paint Q&A
Wizards: need some sage wisdom on the above topic. Those that have painted their calipers, please comment on: 1. durability 2. maintaining the 'AMG' logo 3. pix of different colors on the car 4. best products, etc. Pardon the neurotic concern but I want this potential job to look 'right and tight'. Thanks in advance. P.S. I did a search but not too helpful. Joker
Old Jan 11, 2006 | 10:45 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
If you want it done "right" - go get them powdercoated.
Old Jan 11, 2006 | 11:12 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Eastwood Brake Coating System
I have to preface this by the fact that I have never used this product, however...Eastwood products are excellent and am considering using it. So, food for thought...powdercoating is the best method though if you want to last. Check this link ------> Eastwood Brake Coating
Old Jan 11, 2006 | 11:15 AM
C43AMG's Avatar
Veteran: Army
I might want to add also - if you're pulling the calipers of to powdercoat , you might want to consider installing stainless steel brakelines on your beast also!
Old Jan 11, 2006 | 01:11 PM
X55's Avatar
X55
2001 E55
1. It's as durable as the prep you do. Follow the instructions and CLEAN CLEAN CLEAN before applying. Mine hasn't chipped yet and looks great.
2. Not an issue with my application but for yours some steel wool or a scotchbrite pad would suffice.
3. No pics handy - who cares, put the color on that makes you happy. Understated-silver, Invisible-black, Racy-red. They make other colors but my opinoin is you're treading into ricy territory with blue or yellow.
4. Only have experience with G2 and it was great to work with.
PS I vote no on the powdercoating. Cost/effort for the desired result is out of line. Painting can be done at home in a day. Powdercoating requires complete disassembly, downtime, reassembly, and testing to make sure everything's ok. No thanks.
